Question about Polaroid FLM-3232 Television
How can I fix Polarid TV with no picture?
You can turn the TV on and off - but no picture - do have sound
3 Suggested Answers
SOURCE:
SOURCE: polarid tv-dvd combo power trouble
i need this solved
Posted on Oct 19, 2008
SOURCE: power comes on but no sound or picture
Well there are two options here and unfortunately there's no easy way to tell which is which without opening the TV.
First and actually more common option is failed power supply. It fails in a way that allows it to power the basic TV functionality (main board works, you can power on and off), but it fails to provide power to the backlight so that you can see the display.
If you like digging you can open the back cover and use a voltmeter to figure if both power cables going out of the power board provide 24V . One of the goes to the main board and the power is there in your case (since you can turn on/off and can hear sound), the othe goes through a connector to the LCD's backlight. That's the one you suspect has failed and that's the one you should measure.
if you can see 24V there then it is NOT the power board.
If you do not have 24V there then IT IS the power board. You can have yours serviced or buy a replacement.
See http://blog.coppelltvrepair.com/2010/04/polaroid-flm-3232-power-board-r0804.html or seek around to just buy a replacement.
Now, if it isn't the power board, it might be the inverter that takes that power. Inverter is a bit harder to troubleshoot on this TV model and I will not coever it here.
Finally, there is a minimal risk that this might be due to overheated and malfunctioning main board. Replacement is the only viable alternative here.
Hope this helps!
Bobby
www.coppelltvrepair.com
Posted on Apr 02, 2010
There is no sound from the tv, how do I turn on sound?
About 243,000,000 results (0.42 seconds) Search Results
    10 Ways To Fix A TV That Has A Picture But No Sound ...
    removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/
    Nov 14, 2013 - If your TV has a picture but no sound coming out of the speakers, thereare a few things you can easily check. ... See below for the best solutions to fix a TVwith no sound. ... Television Has No Sound Answer 1: Make sure TV is not muted.
    There is no sound or low volume coming from the TV ...
    https://us.en.kb.sony.com/.../there-is-no-sound-or-low-volume-coming-f...
    Aug 15, 2015 - There is no sound or low volume coming from the TV speakers. Article ID: ... Make sure no headphones are connected to the TV. Verify that the ...
    Picture But No Sound TV - Bright House Networks Support
    support.brighthouse.com/.../Picture-But-No-Soun...
    Bright House NetworksIf you have picture but no sound. Press to ... Ensure that the audio and video cables are connected to the same inputs on the TV. For example, if ... My BHN App.
    No sound from my TV via HDMI when my cable box is ...
Jan 21, 2016 | Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
How do I get picture on polarid tv fml2011
turn it on and have a cable or an antenna attached to the proper place on the back .
Aug 09, 2015 | Televison & Video
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Cannot shut off polarid tla01911c flat screen tv
Press the power button on it. That usually helps. In case you're wondering it's the bottom button on the right-hand side (The TV's left.)
Dec 19, 2008 | Polaroid TLA-01911C TV
TV has audio sound and no picture
major repair; requires 16 pin ic
Apr 19, 2008 | Televison & Video
Polarid tv-dvd combo power trouble
TROUBLE WITH REMOT CONTROL. I CANNOT PROGRAM MY DIRECT DISH
Jan 02, 2008 | Polaroid FLM-3225 32 in. LCD Television
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Polaroid FLM-3232 Television Logo
49 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
