Hotpoint Ultima WF865 Front Load Washer Logo
A
Anonymous Posted on May 12, 2014
Model number wt640 is flashing f-02 - Hotpoint Ultima WF865 Front Load Washer
kenneth southwell
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 28, 2015
kenneth southwell
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
51
Points
This is a overheated pump replace pump or clear blockage to let pump run faster as slow pump can give a f-02 fault
My stove is flashing F7 02 CODES With constant beeping.
First things first. Brand and Model number. Although most fault codes have are similar across major appliances it is necessary to find a correct solution.
WT640 Not completing spin cycle.
thats a front loader
the user manual might have the error codes listed
think its a direct drive model
only part of that description suggests its the printed circuit board
are you using a surge protector at the wall power point
Hotpoint WT640 Instructions For Installation And Use Manual
1helpful
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
My Hotpoint wt640 has an error code F-05, what does this mea and what should i do??
My Hotpoint wt640 has an error code F-05, what does this mean and what should i do??
5helpful
Hotpoint WT640 - it's flashing f-05. I emptied the machine and put on another wash and it says the same thing halfway through the cycle?
F-05 normally relates to the pressure switch,which normally points to a blockage.Does the machine empty slowly if so I would check the drain pipe first and if that is ok then you need to look down at the drain pump which may have a blockage in the filter which is inside the sump pipe,this is the main hose from the base of the drum and goes to the pump.
Hope this helps.
2answers
F 02 flashing on washer
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Can You Tell me which one is this Model, It is written as Philips GoGear 2GB, its an Flash based player, Not a Harddisk type one. The Link for the photo of Player is...
The player with Image046.jgp, looks like the SA31xx series.
When it's an audio player only, it will be the SA3123.
For exact type (Functions and Drivers & Software could be different !):
United Kingdom: SA3123/02
United States: SA3123/37
If the device can play both audio and video, it could be either the SA3124 or the SA3125.
United Kingdom: SA3124/02 or SA3125/02
United States: SA3124/37 or SA3125/37 or SA3125/37B
A user manual for the SA31xx series player, can be found on next page:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA3123/02&slg=en&scy=GB
note:
When selecting the User manual, the model SA3123 is not listed on the first page in the pdf file, becaus it will have no video function (video, only on players, ending with 4 or 5)
Model 30gx faults code
Hi, the indoor chiller unit blower section will have a sheet glued to a panel on the unit that will tell you where and what the code 302 means on the unit. Then you will be able to make the repairs you kneed.
Shastalaker7
PS the numbers above show that this is a 3 ton unit, 38CKC036. The error code more than likely will be 3 flashes from the board followed by 02 flashes. I may be wrong on that , so correct me if I am.
2helpful
Wash stops, beeping, flashing F and 02
I'll just take a swing at this one, without model number.............F-02 is typically a Whirlpool error code for " slow drain". If this is a Kenmore or Whirlpool front loader, pull off the bottom panel and check the pump filter, (pump should be right up front, turn counter-clock-wise to remove filter) clear of any debris, check hose from tub to pump as well. NOTE! If there is water in the machine, it will pour out of the pump, first remove the water either with a wet-vac, or just do it very slowly and carefully at the pump, draining the water into a pan.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
