04-05 Sg5 Front Lip Ds-Style Urethane Logo
Jaime Muro Posted on May 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clarion cz301e how to connect this stereo to thr car harness
Joel Friedenberg
Level 3:
  • Master 1,114 Answers
  • Posted on May 13, 2014
Joel Friedenberg
Master
Level 3:
Answers
1114
Questions
0
Helped
440531
Points
3272
You can purchase a harness adapter that will plug into the original radios harness. The other end of the adapter harness has loose wires with tinned ends which you connect to the new radio's harness, which as the same colors as the adapter wires.
  • Metra Model: 70-8901 is one adapter that I believe will work.
  • Scosche item Number: 16845632 is another adapter.
  • If you want to buy locally, Best Buy will probably have one or the other. If you want to buy on line, just do a search for the name and model numbers.
Subaru ForesterReceiver Wiring Harness
2answers
I need the wire conector for car stereo. Clarion 2261f
You are most likely going to need to retrieve that from the Clarion manufacturer. Cost is usually 35-50 US Dollars.
1helpful
I need a wiring diagram for a Mitsubishi Stereo DX-262AL. I want to replace it with a Clarion CD stereo, which I need to "marry" to the existing DX-262AL car loom. Any help much appreciated.
Option 1: If you haven't purchased any components yet.
If your Mitsubishi still has the original OEM (factory) wiring loom, then the newest method of connecting an aftermarket head unit (i.e. Clarion) is by using a 'snap-on' adaptor harness which eliminates the need for any cutting/joining/soldering.
The adaptor you want is the Mitsubishi-to-Clarion type: one end of the adaptor has the Mitsubishi (female) plug and the other has the Clarion (female) plug.
These adaptor looms can be purchased from most automotive accessory shops, or you can purchase very cheaply online from Ebay.
Check this link (this is the Clarion MAW2-16 adaptor for 1995-2004 Mitsubishi vehicles) @ USD $1 + $11 shipping (Note: the Year of your vehicle will determine which harness you require):
http://cgi.ebay.com/CLARION-MITSUBISHI-FACTORY-WIRE-HARNESS-ADAPTOR-95-2004-/370521783457#vi-desc
Option 2: the hard way
If you REALLY want to do it the hard way and start cutting wires, then here is the wiring colour codes:
EARLY MITSUBISHI AUDIO CONNECTORS:
LATER MITSUBISHI AUDIO CONNECTOR (SINGLE TYPE):
I trust this answers your question? :-)
"If this has helped you, please take a moment to rate this solution. As always, I do appreciate personal testimonials from Fixya customers, after I have offered technical support. Thank you."
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Installed a clarion radio it powers up but no music thru speakers
sounds like a short in your wiring to your speakers the best thing to do to check this is run a speaker wire directly to the speaker from the stereo check it that way and see if it works.If that don't work it's the wires on the stereo connection.The speaker wires on most aftermarket stereos are mostly colored 2 of each green,purple,white & grey.
2answers
I NEED A FEW THINGS FOR MY CLARION STEREO
Go to pacparts.com and you will find any CLARION accessories
INSTALLING A CLARION MODEL DRX6375 CAR STEREO INTO MY HONDA ACCORD 1995
If you go to your local stereo shop (or even Wal-Mart..) you can get the harness that plugs directly into your cars wiring for about $5-10. It will have the EXACT same wire colors as the harness that came with the Clarion. Just match them up, plug it in and you're good to go!
1helpful
4answers
Car stereo wiring
http://www.clarion.com/us/en/MungoBlobs/752/342/VRX755VD-English.pdf
Clarion Xmd3
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Top Subaru Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Subaru Vehicle Part and Accessory Expert? Answer questions, earn points and help others
