KitchenAid KSM150PS Artisan Series Stand Mixer Logo
A
Anonymous Posted on May 12, 2014
Model # 2351 Tilt is locked closed
I just finished a batch of dough. I can not get the Tilt to tilt back. The lock is stuck or something. I can see through a tiny hole in front that the lock button is trying to click but except for a little movement it will not release.
Appliance engineer
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • KitchenAid Expert 225 Answers
  • Posted on Oct 09, 2019
Appliance engineer
KitchenAid Expert
Level 2:
Dedicated:
Answers
225
Questions
Helped
101126
Points
532
Hello there,
Sorry to hear you are experiencing an issue with your appliance, it sounds like you might need a new tilt lever. Please see below the help video for your perusal as well as quote for a replacement one, should it need replacing:
4176024 KitchenAid Lever-Latch Black was 9709280, 9709267 tilt https://secure.kaparts.co.uk/sku/4176024
3 Related Answers
Anonymous
  • Posted on Jan 01, 2009
SOURCE: Mixer won't tilt back
You may need to remove the head from the base to find the problem.  This is a simple procedure, and is easily reversed, so if it doesn't help you, you can just put it back and take it to a repair shop later.
To remove the head:
First, make sure to unplug the mixer unit!
Next, turn the unit upside down.  Inside the neck, you will see a screw.  Use a slotted screwdriver to loosen (turn counter-clockwise) the screw a few turns.  This will release the pivot pin on which the head swivels.
Push the pin out from one side using a long, slender implement (a screwdriver, pen, etc.).  With the pin removed, the head will lift off of the base, and you may be able to determine the problem from there.
Best of luck!
Anonymous
  • Posted on Dec 10, 2010
SOURCE: Dough blade is scraping the
If you're still having this problem, here's what I did a few minutes ago that fixed it. Lift the head, then turn the screw that connects the head to the base to the left. You're basically unscrewing it. That screw regulates how high or low the beater is. Unscrew it a little at a time, and lower the head and try to lock after each turn. The head will gradually get in a more locked position. Keep turning the screw till the head finally locks in all the way. Read the "beater to bowl clearance" section in the manual.
Anonymous
  • Posted on Jul 17, 2012
SOURCE: My KitchenAid tilt head lock
In my case the lock was not engaging fully because the internal mechanism was bent too short. I'm not sure if this happened over time or if it is just a manufacturing defect. If your mixer still has some up-and-down play to it when the lock is engaged, then you might have the same problem as me
To fix it, search this site and others for instructions on how to remove the motor cover. I found this video useful: http://www.youtube.com/watch?v=VeCiivPt7hk
With the cover removed you have access to the locking mechanism. In my case, the latch is connected to the locking lever via a bent S-hook. The hook was just slightly too short which kept the latch from engaging completely. If you remove the two screws holding the hook in place and that allows the lock to close completely, then you have the same problem as me. (You'll feel the difference immediately. When fully locked, there is practically no wobble in the mixer head.)
I lengthened the hook by placing it against a flat surface and hammering the bend out a bit.
After mixing bread dough the mixer head will not tilt up to get the dough out of the bowl
Push the head down before pressing the button on the mystery mixer. There is probably dough under the hook with it pressing the head up and is locking the catch.
You can pull out the dough around the dough hook to make it easier.
All questions need 'make model (what it is)', first 3 words please
Nov 25, 2023 • Food Mixers
Tilting the head back wheres the button.on the kitchen aid mixer
Model?
Look for the tilt lock lever on opposite side from speed control.
How do you tilt the head back on this k45 model?
You will find a sliding lever on the side opposite the speed control. Pushing it toward the rear will unlock the head and allow it to be lifted.
If this does not work, you will need the Service Manual which shows the locking mechanism's action:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Lock tilt head
You will most likely have to take this apart to get it out again. Over all not really that hard.....about 6 screws to get the top off. If you don't want to go that route the only suggestion I have is to get a really strong magnet and try to manipulate it out with that.
1helpful
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Bread dough beater will not come off
as far as possible.
Dough blade is scraping the stainless bowl. The mixing head seems to be sitting lower. In order to lock the tilt I have to lift the head a little.
I can't get the tilt release to release to raise the mixer . I have a batch of cookie dough in the bowl and I am unable to raise the mixer
Try running the mixer for a few seconds to clear anything out from under the beaters, like a chocolate chip. You can also try pushing down on the beater end of the mixer, press the button and lift.
2helpful
The tilt button is not working
Okay, we just figured this out ourselves.
There is a little hole on the neck of the mixer, where the mixer motor meets the neck. While pushing the tilt release button, stick a small screwdriver into the hole (it will not go far) and pry the latch upward. While holding the latch up and the tilt button, have someone pull up on the motor while holding down the base. It might take a little muscle, but after that, the motor will be able to tilt back and forth like it did before it got stuck. If you are the one holding the tilt button and latch, please wach your finger so they don't get pinched when the motor swings up.
Mixer is stuck in the down position
If the mixer is under a year old and you have a receipt, send everything in,beaters, bowls, book, etc, to Authorized Appliance and Repair in St. Louis Missouri and you will receive a brand new replacement or ungrade free of charge. Make sure you have your Name,address & phone number with the unit.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
