When I was trying to sync more mp3 songs from my pc to my mp-556 it deleted all my songs. Since I no longer had a playlist so I copied the mp3's to an SD card, but the mp3 player won't load it. Did I do something wrong?
SOURCE: MP-556 MP3/WMA PLAYER
http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
SOURCE: Got a new SD Card + Card Reader but when I download my music on it...
You cannot just move WMA songs onto the card and play in the MP3 player. MP3 format may work this way, but for sure the player only seems to be able to recongize WMA files when syncd through Windows Media with the USB cord attached. Be sure the DESELECT 'copy folder hierecy' under the sync options/properties of the MP3 player drive or SD card drive.
When using XP Pro and Windows Media Player you can transfer WMA but you have to go into the PROPERTIES of the drive (mine was mp-556/G: drive) and DESELECT the option to transfer folder hierecy. The MP3 player is not able to reconginize the folder structure it usually creates.
This player only seems to be able to transfer MP3 format with Vista, using windows media player sync. I can syne MP3s formats, but not WMAs at all. Unless someone found otherwise
SOURCE: problem on mp-556
There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything.
-Tha Mp3 Doctor
SOURCE: add and delete songs
Windows Explorer or windows Media Player - instructions available from Microsoft website
wat i dnt no wat the **** r u talkin about
