Garmin c330 shuts off for no reason. The battery shows fully charged.Garmin c330 shuts off for no reason. The battery shows fully charged.
AnonymousMar 12, 2008
c330 will not come on.
I have tried changing cords.
I have tried letting it charge for awhile.
It was working fine when i took it out of the truck and put it in the box and when i got it out a week later it would not come on.c330 will not come on.
My garmin330 keeps shutting off.Hve already called support a couple of months ago,and now doing the same thing.Have charged it on my computer,have checked the fuse,and the connection. It shows fully charged when it goes off. It ges on with no problem ,then dims and goes right off.My garmin330 keeps shutting off.Hve already called support a couple of months ago,and now doing the same thing.Have charged it on my computer,have checked the fuse,and the connection. It shows fully charged when it goes off. It ges on with no problem ,then dims and goes right off.
LIGHTER IN 2005 CROWN VIC DOESN'T GIVE ENOUGH POWER TO KEEP GRMIN ON. WON'T WORK IN LG TRUCK, HOWEVER WORKS IN A SM. TOYOTA TRK. WHAT HAPPENED?
APPREICATE ANY HELP.
THANKS
CAROLLIGHTER IN 2005 CROWN VIC DOESN'T GIVE ENOUGH POWER TO KEEP GRMIN ON. WON'T WORK IN LG TRUCK, HOWEVER WORKS IN A SM. TOYOTA TRK. WHAT HAPPENED?
THANKS
CAROL
You can't post conmments that contain an email address.
You have to pry off the silver-colored faceplate from the unit and you will find a reset button on the right side of the screen. Push this and everything will back to normal.
I've had a couple of Garmin C330 units and a C340. They're good quality except for the flimsy power plugs. My first one out of the box had a defective plug which made intermittent contact when I plugged it into the lighter. Tightening the knurled nut on the tip of the plug helped somewhat, but didn't fix it completely. It became a non-issue after I bought a friction mount which came with a better cord and plug. The friction mount also stopped the problem of the suction cup constantly falling off the windshield.
Go to www.garmin.com and read about "Map Updates" Enter your unit's serial number and see if there's a newer map available. It will explain about how to buy and install the update.
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
Make sure that you age getting power from the plugin.
Test: With the unit OFF plug adapter into cigarette lighter.
The Garmin should turn on automatically. If it does not,
you are not getting power to the unit. Make sure you have
good connection at the holder.
Generally it powers off by itself because it is not receiving
power from the plug.
Just keeps shutting down. Sometimes it says low battery before it shuts off.It has been plugged into car all the time.Where is the battery.
Fred Reid
garmin will not charge
THANKS
CAROL
