Kobo Arc Logo
A
Anonymous Posted on Mar 05, 2018
Hi, i have a kobo arc, and recently it has stopped working. The light stays on, and every time i go on it, it freezes and i cant do a thing with it. not even turn the screen off, or do the volume or turn the thing off. Can you please help me with some advice?
Jackie Mills
Level 2:
Sergeant:
  • Expert 386 Answers
  • Posted on Mar 05, 2018
Jackie Mills
Expert
Level 2:
Sergeant:
Answers
386
Questions
0
Helped
119546
Points
871
Hold the power and volume button at the same time till u get a box and a tool thing on your screen the by using the volume down go to wipe data press power button to ok then go down to yes with volume down key and press the power button to ok yes then will reset your tablet like when first got it
Hello , I have a kobo arc7 won't stay on
Do you mean the battery dies? That would be the most common cause of this kind of problem.
My kobo arc 7 screen is not responding to touches. Can it be reset?
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Kobo Arc to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Kobo Arc and including third-party applications.
9. The Kobo Arc will reboot to its original data.
10. This time you can restore your backed up data to your phone.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
My kobo wont turn charge and turn on
Broken psu connector or moethboard junk it its not cost effective to repair.
Aug 20, 2014 • Kobo Arc
1helpful
2answers
How do i repair the charging port on my kobo arc the cord will not fit?
That's a tough job unless you can send it back.
You can charge it with a USB cable and aPC, however it is slower but it might work.
Try that first.
May 17, 2014 • Kobo Arc
3helpful
2answers
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 • Kobo Arc
2helpful
I need a kobo arc manual
No Probs,
Copy and paste this link.
merch.kobobooks.com/.../Arc/kobo_arc_user_guide_en.pdf
Nov 18, 2012 • Kobo Arc
Top Kobo Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kobo Tablet and eReader Expert? Answer questions, earn points and help others
