How do I set this timer no segment pins
Http://waterheatertimer.org/Woods-timers-and-manuals.html#50000
Segments are located around the dial
http://waterheatertimer.org/How-to-set-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: We can't figure out how
Hi Joy and Fred.
You posted under Woods outdoor timer, but don't give specific brand or model
Open following links for detailed information and illustrations:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#59383
Segments are usually on outer edge of dial.
Some timers the segments lift up, some push down, some pull up and out, etc.
Use a fingernail or small tool and fiddle around with it.
Some timers have pins located on dial face that click inward or outward. Use small tool and move them in and out.
Some timers have trippers that you attach to outer edge of dial.
If you are confused, open links above for illustrations.
After moving some segments-pins. Plug lamp into timer.
Turn lamp on. Plug timer into outlet.
Manually rotate timer dial and watch how lamp turns on-off.
Move timer switch both directions and manually rotate dial to see lamp turn on-off.
These tests will show you how to set pin-segments-trippers and switch for your specific timer.
The timer dial rotates as time passes. The dial is a simple clock that rotates because of a clock motor.
The dial causes segments-pins move small lever that turns lamp on-off.
Just like any clock, the correct time has to be set. To do this: rotate dial until current time lines up with arrowhead located on inner dial.
For more information, add a comment with in-focus photo of your timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
