E display shows 35 degrees
SOURCE: temp -35 degrees,freezer runs all the time
I assume there is no manual control for setting temp. so the thermal sensor or control circuit has failed and it is just staying at its maximum.
You will probably get more help from the manufacturer but their website is somewhat disjointed; looking for contact info for your product ends at one point and then shifts to their scientific product line.
The only general contact info I found is here:
Nor-Lake
You will in any case need to have the correct model number at hand since the subject line doesn't sound like your freezer.
SOURCE: Freezer is around 3 years
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
