Turn on and use safe mode Safe mode allows you to turn on the device with third-party apps disabled. Then you can easily uninstall apps that may be causing a conflict or software problem.
Turn the device off. Press and hold the Power key. When Samsung appears on the screen, release the Power key. Immediately after releasing the Power key, press and hold the Volume down key. Continue to hold the Volume down key until the device finishes restarting. Release the Volume down key when you see Safe Mode on the device. Uninstall apps that are causing a problem.
Turn off safe mode Press and hold the Power key. Tap Restart. The devices restarts in normal mode.
Hi Anonymous, just press the home button or if you enable the assistive touch you can tap it and then tap home.
and to totally close the apps open, double tap the home key then tap the apps below which will be appearing after you double tap the home key then tap the "x" or just swipe up.
For the TI-89 Family, TI-92 Family, and Voyage 200:
Try a new set of batteries (including the backup battery).
Adjust the contrast by pressing and releasing the Diamond Key key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps. On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...".
Users of the Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps. On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore OS
Finally, try with new set of batteries (including the backup battery).
check the other keys (ctrl, alt, Fn) if they are stuck. When you mean apps part, do you mean the apps on the functions keys? If so, you should be pressing the Fn key usually located at the lower left of your keyboard.
Try to hard reboot ... Press and HOLD home key and power / stand button ... you will see switch off screen... keep pressing both buttons... phone will off.. dont leave the phone.. once the phone start turning on you may leave both keys..
Press the APPS key, then select any of the language apps (Deutsch, Espanol, Francais, etc.) and press ENTER. Select English from the menu and press any key when prompted to do so.
Have you tried to reinstall the drivers from the recovery apps? If you go into the recovery process, it gives you the options to recovery the whole system or just the apps. Choose the apps and this should correct your problem. (If you can not recover the apps without recoverying the whole system, go to eMachine support page for driver download.)
That circles mean the progarm is running. The n95 keeps apps running in the backroun. To see the apps running u can go in to the menu and look for the circle, or u can press and told the menu key this will give u a list of the apps. U can also exit the programs from this by hitting the clear key. If you press the end key or exit the progarm with out hitting the exit button then it will keep running.
