The only trap on a Kenmore Elite HE3 is in the drain pump. The following link explains how to access and clean it out:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link provided and let me know if you have any questions. I personally own one of these washers and have repaired them many times. If you are experiencing drain problems, the problem will most commonly be attributed to the drain pump trap becoming clogged with debris. There's usually an error code associated with this problem of "F02". If you attempt to clean the drain pump and you discover the pump to be clear, check the drain lines (especially the line running from the bottom of the wash tub to the inlet side of the pump). If all these preliminary checks don't solve the problem, the manufacturer recommends replacing the drain pump.
If this is not what you were talking about, please post back and elaborate a bit more so I can understand the problem you are having. I hope this helps you.
I have a Kenmore Elite top loading machine I am looking for the lint collector. Can not find it. Can not find the model number or anything. Just Kenmore Elite nothing else. Bought in January 2006 has, dials not buttons, nothing digital, if that helps. It never does drain completely why the heck NOT???? That is crazy. I dyed some cloths and t says to clean the lint trap afterwords, WHERE is that darn lint trap???
