How do I turn on the spa with an Aquapod?
In the Aquapod remote control, press the "Menu" button until the settings menu appears.
Use the right arrow to find the "Teach Wireless" option and hold the plus button until it says successful.
On the pool control local display/keypad, press the "Menu" button until the "Settings Menu" is displayed.
Use the "<" or ">" buttons until "Teach Wireless" is displayed.
Press the "+" button to start the teaching process .
Turn the top valve 180 degrees to switch from pool return to spa jets.
Turn the bottom valve 180 degrees to switch from pool suction to spa suction.
Turn the gas on at the heater.
Press the spa button on the heater and adjust the temperature if needed.
Turn on the timer and make sure it is not past the off trip.
When done, turn the heater off manually and switch the valves back to pool mode.
Hi Peter Kavila, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is that the right device that is showing with your question? Can you tell us what you are doing with it?
