Brother MFC-8440 All-In-One Laser Printer Logo
b
banwari Posted on May 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
6F problem in Brother printer how check the problem
Pls give me solutation for the same
nishanth kumar c
Level 2:
Habit-Forming:
  • Expert 150 Answers
  • Posted on May 10, 2014
nishanth kumar c
Expert
Level 2:
Habit-Forming:
Answers
150
Questions
Helped
43830
Points
195
Please check the fuser unit side
  • nishanth kumar c May 10, 2014
    please check the fuser unit side
My brother printer is not working (Displaying showing Print Unable 6F) modle no MFC-8880DN
6F in a Brother laser machine seems to refer to either a faulty thermistor or faulty power Supply PCB. In either case the unit would need to be replaced. The machine is "obsolete" but not that old so repair is worthwhile especially if the machine has done less than 50K pages
Brother mfc-j430w error message 6F what does it mean
6F indicates "The machine does not work due to a paper jam or some sensor problem." Hope this helps.
Get an 'unable to print 6f' error for my MFC-8370 machine.
https://help.brother-usa.com/app/answers/detail/a_id/145079/~/unable-to-print-6f
"Unable to Print 6F"
The message "Unable to Print 6F" will appear on the display for one of the following reasons:
i. A foreign object, such as a paper clip or ripped piece of paper, is stuck in the machine;
ii. Mechanical malfunction.
To attempt to clear the error, continue to step 1.
1. Using both hands, use the finger holds on each side of the machine to life the scanner cover into the open position.
- Do you see the scanner cover support arm located on the left side of the machine?
- If yes, go to step 2.
- If no, verify you have opened the scanner cover (as in the image above). If the document cover was opened, you won't see the scanner cover support arm. Close the document cover and go back to step 1 to open the scanner cover.
2. Carefully check the left (2) and right (3) hand corners and the center inside the machine and remove any paper scraps that may be jammed.
3. Using your hand, move the print head from left to right, checking carefully for any paper scraps stuck under the print head. Remove any if found.
If the print head is in the right-hand corner, press and hold down the for at least 5 seconds until the print head moves to the middle. This will allow you to check the right corner inside the machine for any paper scraps.
4. Leave the scanner cover open and turn the machine around so you are looking at the back of the machine.
5. Open the Jam Clear Cover (1) on the back of the machine.
6. Check inside for any foreign objects or jammed paper. Remove it found.
7. Close the Jam Clear Cover, then turn the machine back around to the front.
8. Lift the flat-bed scanner cover to release the lock (1), then gently push the scanner cover support down (2) and close the scanner cover (3) using both hands.
- If "Unable to Print 6F" still on the display, go to step 10.
- If "Unable to Print 6F" has cleared, go to step 11.
10. Unplug the machine from the power outlet for approximately one-minute, then plug it back in.
- If "Unable to Print 6F" still on the display, go to step 12.
11. Print a Print Quality Check Sheet (PQCS).
a. Press on the Touchscreen.
b. Press Test Print.
c. Press Print Quality.
d. Press OK. A PQCS will print.
- If the PQCS print successfully, your machine is working properly. The issue has been resolved.
- If the PQCS doesn't print because "Unable to Print 6F" reappears and you have not cycled the power, go back to step 10.
- If the PQCS doesn't print because "Unable to Print 6F" reappears and you have cycled the power, continue to step 12.
12. Your machine will require service. Any faxes received while the error message is on the display will automatically go into the machine's memory due to the product's inability to print. If there are faxes in memory, you can transfer them to another fax machine so they are not lost.
- If you don't want to transfer faxes, go to Warranty and Service Options.
- If you want to confirm and transfer received faxes in memory, go to step 13.
13. Transferring stored faxes to another machine.
To transfer data from your fax machine to another fax machine, you must have already programmed the Station ID in your machine prior to getting the "Unable to Print 6F" error message. If you did not already have your Station ID programmed into the machine before getting the error, you will not be able to transfer faxes in memory. Continue to Warranty and Service Options.
a. Press to temporarily interrupt the error message.
b. Press on the Touchscreen.
c. Press All Settings.
d. Press ? or ? to display Service. Press Service.
e. Press Data Transfer.
f. Press Fax Transfer.
- If "No Data" appears there are no faxes in memory to transfer. Press , then continue to Warranty and Service Options.
- If there are faxes in memory, the display will prompt to enter a fax number. Enter the fax number including the 1 plus the area code, then go to step g.
Warranty and Service Options:
Your machine has a two-year limited exchange warranty. You may use the link below to find a Brother-authorized service center in your area. You may also contact Customer Service for additional warranty options.
Locate a Brother Authorized Service Center:
https://www.brother-usa.com/service/
Contact Brother Customer Support:
https://www.brother-usa.com/askus/ Click here to display all models covered by this answer.
Was this answer helpful?
9helpful
2answers
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
18helpful
3answers
My brother DCP-165C clean unable 50 problem, i can not use my printer due to this problem, what am i gonna do' pls. help?
my brother DCP-165C clean unable 50 problem, i can not use my printer due to this problem, what am i gonna do' pls. help?
4helpful
2answers
Mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Machine error 6F on a brother mfc-8440
first what is the message???? i will try and help you whenn you let me know the problem or the error message
Norman Weimar
Norman Weimar
k24674
