SOURCE: how do u pare jabra 2080 with phone lost
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
SOURCE: Jabra 2080 won't connect. Blue light flashes
I apologize you having trouble with your Jabra Blue tooth Headset.
The reason why its flashing is because it has not paired with a device or the battery may be low.
1. Take the battery out of the unit to fully reset the unit.
2. Put the battery back in the unit "turn the unit on"
3. Try using the code 0000 this is the default code to pair the headset with your hand set.
If the above steps does not work it might be because of a low battery, Thus I would recommend purchasing a new battery for it then try the steps above again.
Again we apologize your having issues with your headset, if you have any further questions please get back with me.
Thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: need operating instructions for Jabra BT 2080
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
SOURCE: Hi . Where to purchase
You can purchase ear gels for a Jabra BT 2080 headset from " http://shop.ebay.com/i.html?_nkw=jabra+bt2080+ear+gel".
Good Luck.
