SOURCE: HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
SOURCE: extra blank sheet of paper with each faxed page
Refer to this link this will help you to resolve your issue.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=20342&lc=en&dlc=en&cc=us&lang=en&product=2512008
SOURCE: hp5510--will fax, bukt when it prints, the sheet is blank.
First print a standalone test page.
Push Setup >> Print reports >> Self Test report.
If the page prints fine. Reinstall the software. It will work !!
Best Of Luck.
SOURCE: Recived faxes only print out blank pages
Someone sent you fax upside down. If your machine prints and copys OK, it's not your machine.
SOURCE: when i recive fax or when i print it just it
If the fax is acting like it is printing (print head moving back and fourth) then it sounds like the ink cartridge is clogged. Remove the cartridge and clean with cotton swab and rubbing alcohol. If this helps a little or not at all replace the ink cartridge. If it still prints blank, the print head could be the problem (this is where the ink cartridge goes). At this point it would be cheaper to replace the fax.
