SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
SOURCE: I was given a Razor E300 and was told that the
You have to make sure that the batteries are still good.
Take a volt meter and read the levels that the batteries are producing. If the levels are too low, then your batteries may have sat, unused, for too long. SLA (Sealed Lead Acid) batteries will generally lose their charge holding capabilities if you leave them in storage for too long without charging them.
YOu can get replacement batteries at this online Electric Scooter Parts Store:
http://www.partsforscooters.com/s.nl?partner=URBANSCOOTERS
-Jackson
http://urbanscooters.com/
SOURCE: My sons razor E300 duns only at about 2 mph on a
You can diagnose your scooter's issues with a volt meter.
test the batteries and make sure that they are putting out sufficient voltage/amperage.
Test the Throttle to see if the regulator is working smoothly.
Test the Controller to ensure that it is working properly, as this is the scooter's "brain".
Check the fuse(s) to ensure that you are connected, and also check wiring for broken, shredded, or burnt wires.
Most likely you need new batteries. If you leave SLA batteries in storage for too long, without use, the batteries lose their charge holding capabilities. SLA batteries hold a charge through a chemical reaction in the Acid Liquid in the batteries. If the chemical reaction settles, the batteries will not accept a charge anymore.
Generally, you don't want to leave SLA battery powered scooters unused for much longer than 3 weeks. :)
-Jackson
