The problem you're describing with the KX-DT333 night mode message bank not working could be caused by several factors. Here are a few steps you can try to troubleshoot the problem:
Check the night mode settings: Make sure that the night mode settings are configured correctly and that the message bank feature is enabled.
Check the message bank settings: Make sure that the message bank settings are correct and that the message bank is not full or locked.
Check the phone's firmware: Make sure that the phone's firmware is up-to-date and that there are no glitches or errors.
Check the phone's connection: Make sure that the phone is properly connected to the telephone line and that there are no loose or damaged connections.
Consult the manual: Consult the manual for specific troubleshoot and service information for your KX-DT333 model
Check your Sim card with another phone that you can receive messages on it. If it does, then check your phone s message spam settings. May it's switched on and prevents receiving messages.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
check your data or files such as messages,photo,video etc. whether it's too many stored on your phone.delete unused data/files so that phone memory able to save space to operate the phone smoothly.
try to test another phone and insert your simcard and check if will works,if its working,then phone has the problem.
reset your phone by going to settings > master reset to restore your phone into default,remember that all data will be erase if you continue this method,be sure to back up everything that is important before doing so.
sending message came from the simcard sms setting...... check your message setting like message center..check the home network what simcard you used. by the way your phone receive message you can call or receive call if yes the problem of your phone is wrong message center number... check it go to message/message setting/message center. check the number if correct or not..
That means there is a message. If it's blinking at the top of the phone it means that you need to check your messages. After you check them the blinking will stop.
