Radio wont come on but cigarette lighter is working. where is the radio fuse located for a 2005 Malibu classic
You may want to check this site Jeffry.
Where is the fuse box located in 2005 Chevrolet Malibu
There is a fuse at the back of the radio , remove the radio and replace fuse
SOURCE: chysler 300tour
if it isnt located under the dash or in glove box check when you open dricer door and look on side of dash if not there then its under hood
SOURCE: lighter and aux power outlets don't work. Where is the fuse
check fuse panel under dash and hood
SOURCE: cigarette lighter fuse blows out too often, which
its not a 20 amp fuse,its a 5amp fuse, I had an XM Roady and its the plug they use on the radios power supply plug,they are cheap, buy a new cig lighter plug and wire it to the XM Radio power supply plug, and it will cure your problem
