What is the correct device code to use when programming a URC-200 Universal Remote to operate a Dish ViP722DVR? Manual says to use 122, it does not work. Then tried using the UP option for next code search and did not find any code that would work. Remote is working fine for TV and Audio system.
SOURCE: I have a UNIVERSAL remote control URC-R6 andi cant
Hi there. I have a link to a manual that you can print out for further use. Click here to access this pdf
SOURCE: need codes for rca tv using ge universal remote
Here Are Some codes 000, 003, 004, 005. 006, 007, 019, 096, 098, 099, 100, 101, 102, 103, 129, 179, 181, 188, 190, 203, 212, 233. For t.v.'s............Hope this is help full.. : )
SOURCE: Cannot program Dish Universal Remote for Emerson TV
This worked for me. I had to scan down quite a few times but eventually my tv turned off and I set the code with the # button. It may work for you too and save you some money on a UR.
http://www.satellite-tv-planet.com/DishNetworkRemoteControlProgramming.htm
Scan For Device Codes
If the code for the device you are programming is not listed in the
user manual or on this site, try these steps to scan the remote
controls memory for device codes.
1) Turn the power on the device on
2)
Select and hold the mode button for which you are programming, such as
the TV button, on the remote until you see all the lights of the mode
buttons flash. Once you let go, that mode button that you chose should
now be blinking. When using the Aux mode button only use the number pad
to enter 0 for a second TV, 1 for a second VCR/DVD, 2 for a amplifier,
tuner, or cable box. Then press the STAR (*) button.
3) Press the power button on the Dish Network remote control.
4)
Repeatedly press the UP or DOWN button on the remote to scan for the
correct code (do this slowly so you do not skip over the right code for
your device). When the correct code is reached the device will turn off.
5) Press the POUND (#) button to store the code in the Dish Network remote.
6) Press the power button to turn the device back on and try using other buttons on the remote to make sure that they also work.
Sometimes the power button will work while others may not.
