SOURCE: Read Clock while listening CD on Kenwood KDC-MP4028
check on page ten of the manual
heres a link
http://inform3.kenwoodusa.com/manuals/KDCMP4028.pdf
SOURCE: UNLOCK SECURITY CODE
for your kdc-mp528 will work whith code KCAR entered from the remote
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
SOURCE: need the unlock code
All Kenwood Radio Codes are available online sameday service via serial number
Visit www.instant-radio-code.co.uk
SOURCE: Kenwood KDC-MPV619. No remote. Need unlock code for deck.
I had the same problem with my kdc-mpv619. I had bought a new truck that didn't have a remote and the screen says enter code. You do need a remote to fix it, but what they don't tell you is a universal remote will work. I used my direct tv remote and looked up all the codes for kenwood.
The one that worked for me was 30337 (not sure if that would work for you).
1) The way I tested it was go to my stereo and I held down the display button + volume up button. (This should remove the - - - - sign but it will still say CODE).
2) Then you press the 5 button on the remote and if the screen says CODEK then you know the remote works.
(to switch from K to C to A to R press the (>>) button on the screen.
3) Enter the code KCAR (the display will say CODEKCAR)
4) Final Step is hold do the fast forward button (>>) on the screen.
It should work for you after that ;-)
SOURCE: how do i unlock my code for my kenwood kdc-mp435u
it came with it when you bought it....or whoever sold it to you stole it if the original owner calls kenwood they willl work something out.
