Question about FoodSaver Kitchen Appliances - Others
Loud noise when sealing
I have a foodsaver 360 aka 550 that makes way to much noise when sealing. How to make it quieter?
    Sergeant:
  • 213 Answers
I really would follow the first answer given by Lee Eismann, after trying the following. GO for It !
I have had the experience when having Bag Stock sit for awhile. Sealing sometimes takes longer. Often too long. You may want to seal the sides again if the space permits. I always split seal the bottom and top of the bag. But, here is the thing. When the bags are new or old. We have found even after cleaning and gasket dry prep. Extra assistance is the key. After time the lid and droor seal loses elasticity and fluid compaction due to use.
If you get a stubborn situation. Or more. Simply place the palms of both hands with equal pressure from the top outsides towards the center on these style of sealers. That seal that will not, will, and can save you frustration and more unwanted investment.
When the cool fixes are not available . Go with this this one. A Clean Machine with the ring seal is this products cornerstone key. One last tip. Leave at least 4 inches from the center of the vacuum tray to the goods. That is when figuring the over all of the bag. You will nail it shut when the vacuum cranks. Hold until the seal goes out. And double up. You are now; Good, to go.
I have almost all the models. The inexpensive one's work great. So TLC. A touch of tender loving care. Gets you in a happy. Fare Well.
Posted on May 16, 2014
2 Suggested Answers
SOURCE:
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
After the sound stops and the light goes off, I stop pressing the button, but then the sound starts up again. The machine seals and vacuums properly, but I worried that it makes noise again. thank s
I guess your talking about a foodsaver. The noise is from the vacuum pump and is usually a little loud. You shouldn't need to keep your button pushed. Is it working when you just hit the vac/seal button and release? If your holding it the whole time, it may be starting another cycle.
Dec 12, 2013 | Heating & Cooling
Hello, my foodsaver vacc 550 makes a lot of noise while sealing. How can I reduce the noise.
follow this steps and fix it. GOD BLESS YOU
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Sep 30, 2013 | Kitchen Appliances - Others
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
New x-box makes alot of noise ,eg clicking and loud humming .friends new console is alot quieter
You could try taking it back to the store and exchanging it. There is not alot of moving parts in there just the DVD and fans on the back of the unit. I suspect the fans. They offer replacement fans but if it is new your best bet is to exchange it. But, use memory cards to copy off your save games, etc.
Jan 01, 2010 | Microsoft Xbox 360 Console
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
My foodsaver vac 550 vacuum works but it doesn't seal and the light doesn't come on. Any ideas?
Check the altitude adjustment. Also, check for food debris in the intake hole, tube or path. Check for debris on the rubber seal around the sealing strip.
Jul 21, 2009 | Kitchen Appliances - Others
Loud humming noise coming from 360
The loud humming noise is usually the DVD drive. It is very fast but is very loud. If you have the NXE dashboard you can download games to you Xbox 360 to run them from the hard drive (you will still need to put in the disk for copy protection issues). The Xbox should make less noise then. Try to mount the Xbox 360 on a hard surface which is in contact with a soft floor to reduce the noise travelling through your home.
If it is making a loud noise while there is no disk in the drive then take the console to a Microsoft dealer whenever you can to have them take a look at it.
Feb 13, 2009 | Microsoft Xbox 360 Console
Xbox 360 makes revving sound when starting and loading
It's not likely to be the fans. The DVD drive makes a loud whirring noise. If you have the NXE dashboard you can install games to the hard drive so the DVD doesn't have to get up to speed, which means the Xbox will be quieter and you'll have faster loading times.
Feb 06, 2009 | Microsoft Xbox 360 Console
Kitchen Appliances - Others Logo
695 people viewed this question
Top FoodSaver Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
