Vehicle Parts & Accessories Logo
A
Anonymous Posted on May 09, 2014
Screen off the nav screen is off and sometimes only shows logo,,i took the car for re-stitch the steering and once they fix the steering,,screen not working,please advice,tx
Jensen Beach Speed Shop
Level 3:
Master:
  • Master 710 Answers
  • Posted on Sep 07, 2014
Master
Level 3:
Master:
Answers
710
Questions
Helped
141099
Points
7635
Check for a bad or blown fuse. It is possible that they created a shot while working on the car and the fuse has blown.
Sat nav not responding on touch screen peugeot 207 sportium
If the sat nav is not responding to touch on the touch screen of your Peugeot 207 Sportium, there are a few things you can try: Check if the screen is clean: Sometimes, the touch screen may not work if there is dirt or debris on it. Use a clean and soft cloth to wipe the screen. Restart the system: Try restarting the sat nav system by turning off the car and turning it back on again. Check the settings: Check if the touch screen settings are correct. In some cases, the touch screen may be turned off in the settings, so make sure it is turned on. Update the software: If the sat nav software is outdated, it may not work properly. Check for any available updates and install them. If none of these steps work, it may be a hardware issue and you may need to take the car to a mechanic or Peugeot dealer to diagnose and fix the problem.
1helpful
The navigation and radio screen on my 2009 escalade is not working and just blinks the home screen. How can I fix?
Chris, they had a few problems with Escalade nav,/radio usually expensive fix and sometimes doesn't last, a lot of people end up going aftermarket.
1helpful
2answers
I purchased a 2002 Range Rover Borrego recently.
I have experienced many electical demons with all my British cars. The nav units can and do fail. I had a goofy one this summer and the only way it got fixed was to replace it. The module not the head unit
1helpful
3answers
Hi my MMI system on 2004 A6 asgone dead, no power
No solution, same problem, but had many strange moments: 4 months ago during 100 kms or so it stopped, then suddenly came back, and worked ever since. A few days ago, it started happening again: NAV stuck, then radio dead, and gradually the rest disappeared. I did a Reset, and since that moment I see the intro-screen and then it goes black. Hitting the TEL button is somehow also a Reset...
Do the previous 2 posters have anything to report on this matter? It would be VERY welcome!
Thanks,
Jeff
2answers
I reset all settings on my iphone 3G it took over an hour after it was finish all it does is showing the apple logo and it would not go past that. How can I fix it? Can someone help!
I think the only thing you can do now is restore your iPhone to the factory setting. If I can chat with you then I can show you every steps. But you can check on the iPhone manual or just connect to iTune choose restore and do what it say on the screen. Good luck and hope this help ;)
Bluetooth problem
Turn on your NAV screen and go into the info main menu in the Nav system. If no NAV refer to the drivers handbook, since you will sinc by using the voice command buttons on the steering wheel and the car will offer you prompts.
Click on telephone, settings, Bluetooth, ADD PHONE.
Then go into the menu for the Curve, tools , add devices,enable handsfree, search new device are the icons you need. You will need to authorize the Curve to accept a new device by entering a 4 digit pin code, which will show on the car`s screen. Once completed, the car will acknowledge the Curve in it`s screen
TV/Sat nav screen keeps flashing on and off showing Jag Logo
you need a new screen, as there quite tempermental. you should be able to gey a new one from ebay, as ive seen few for sale £100 - £250.
Hope that helps.
You only need screen not the control box ok.
2helpful
Sat nav
ok I fixed it....took out the sat nav and cleaned the lens with a cotton bud..WORKS!!!
Evesham 6400 sat nav
when i turn sat nav on all i get is the evesham logo on screen
Tomtom 910 sat nav.
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
