Janome L-344 Mechanical Sewing Machine Logo
Posted on Jun 22, 2009
Top seam normal but bottom one appears just straight and loose.
I have a" New Janome" sewing machine(harmony 2041) which I have not used for sometime.I have tried all I can to sort out the above problem to no avail .I have no manual to refer to,please help.
Ellen Den Dulk
Level 1:
  • Contributor 25 Answers
  • Posted on Jun 23, 2009
Ellen Den Dulk
Contributor
Level 1:
Answers
25
Questions
Helped
10254
Points
69
If the top thread looks normal and the bottom thread "loops", it means that the top thread does not have tension. Take out all the thread and re-thread the path, giving special attention to the path of the thread through the tension disks.
Thread the machine with the sewing foot up, it opens up the tension disks, and make sure you lower the foot before sewing.
This will close the tension disks.
3helpful
The top stich is loose on my Janome Harmony 8100, I have cleaned and changed bobbins, but nothing seems to help.
Ok, Let's understand exactly what is going on. You said. "the top stitch is loose." So that we are clear....do you mean that you are getting loops on top of the seam? Or do you mean that you are getting wiggly stitches on top and small loops on the bottom of the seam? It's important to know... Because loops underneath means the top tension isn't right. Maybe you didn't thread with the presser foot in the UP position... or your tension is dialed too low.
Now, if you are getting loops on top of the seam... that means the top tension is too tight. Loosen the top tension. Make sure your bobbin is inserted correctly. If loosening top tension isn't enough, you may have to tighten the tension screw on the bobbin case/ or bobbin carrier.
Need to oil janome 2041
the bar at the back is for the foot so the material feeds ahead as you sew, it needs to be down when sewing
I have the Harmony 2041 Sewing Machine but don't have a manual. I would either like to download a manual or at least receive instructions as to how to thread the machine up.
Hi, I looked on their website, as a lot of manuals are free to download, but no luck,
Another fixya user suggests emailing them and asking for a copy.
Use this link http://www.janome.com/index.cfm/ContactUs/Machine_Support
16helpful
6answers
Instruction manual for Janome harmony 2041
Anyone that is still in need of the manual for Harmony 2041 /2049. Please contact me by email and I will email you a copy that I just received from Janome as a PDF file... [email protected] It is 2.7 MB in size.
2answers
Get a solution please
I am a sewer so I can explain to you what to do you lift it up your needle might break. If so you twist the thing and take it out. Then peplace it with the other needle that fixes it.
5helpful
2answers
Manual
I have uploaded the manual to rapidshare, here is the link.
http://rapidshare.com/files/134523596/sewing_machine_instructions_Harmony_2041__English_.pdf.html
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
