Amana SXD524VW Side by Side Refrigerator Logo
A
Anonymous Posted on May 09, 2014
Sxd22s2w what are the specs for this refrigerator?
1helpful
Where is water filter located on amana fridg sxd22s2w, made in 1995/6 ?
Your model does not have a filter. You will have to add an inline water filter before supplying water to the refrigerator if you would like it to be filtered.
Not Cooling and Evap Fan Not Running
Two things come to mind. 1. Something got pulled loose or bent during the move. 2. Mice have made a home (binding up the works) or chewed something important.
R-134 is OK with the cold.
Amana sxd22s2w p1190416ww refrigerator. The Evaporator fan isnt running (compressor and condensor fan running fine) How can I tell if the problem is the fan motor itself, or something else, like temp...
Remove the cover to the fan, then remove the plug from the back of the fan. Connect a voltmeter to the 2 leads. Close the door switch and turn the fresh food thermostat to the coldest setting. This will call for cold and the fan should have 120 volts. If there is power to the motor replace the fan. No power check the thermostat. For help replacing the fan try this link http://appliancehelponline.com/sxsevapfan.html
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
How do I get access to the coils on an Amana model SXD22S2W,
on most refrigerators the plastic grill is a snap on most service tecks carry a long
brush that looks like a cats tail to clean the condenser coils a long bottle brush will also work but be gentle the tubing is metal the fan is normally located looking from the front back left corner if you have a plastic putty knife you can insert on top behind plastic close to the side and easily pop forward very few units are secured with screws ron
Door open all day Amana SXD22S2w
the evaporator is clogged with frost, just as if the defrost heater went out. Two options, remove all food and leave ref unplugged and doors open for half a day, or remove the back wall(evaporator cover) and defrost it with a hair dryer.
Amana refrigerator water dispenser
could be carbon particles from a broken carbon filter cartridge. replace the filter and flush about 5 gallons of water before checking the water again that comes out of the dispenser.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
