If you are seeing the yellow light blinking 3 times repeated over and over the boot
data is corrupted. Download the firmware update(link below)from
Toshiba and
unzip the files and folders,copy the unzipped files & folders to a
SD card (like a
camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs.
Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
