Seconds hand stuck during setting of date. I sahked voilently so that it move but no results. Time is also stopped. how to set date and time on it
Hi Johar,
I will advise you to contact your manufacturer to avoid warranty void due to damage during the process of setting it. Try the link below.
Contact Us TAG Heuer
SOURCE: My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch. Change the battery, and see if the problem goes away. If it does not, then it could be a problem with the stepper motor, which will require a watchmaker. Of course all of this is dependent on the assumption that your watch has a quartz movement. If it is an automatic, or mechanical you have bigger problems.
SOURCE: Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
SOURCE: second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of
that 4 seconds interval movement of seconds hand and thus indicating
the time for battery replacement. The timekeeping is not affected by
this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
SOURCE: seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
