Cars & Trucks Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will a 5.9 from a 99 durango fit a 96 Dodge Ram 1500?
I am wanting to know if a 5.9 motor from a 1999 Dodge Durnago will fit a 1996 Dodge Ram 1500 with a 5.2?
Anonymous
Level 3:
  • Master 721 Answers
  • Posted on Jun 23, 2009
Anonymous
Master
Level 3:
Answers
721
Questions
Helped
257928
Points
1985
Sure,just make sure you get the wire harness & a diagram. Go to town!!
2010 Dodge Charger. Will a 3.7 engine fit?
Fitting is one thing, will it run is another :>D They are computer controlled, so the ECM has to be compatible.
What Engines Can You Put in a Dodge Charger?
dodgechargerca.com https://dodgechargerca.com > blog > dodge-charger-e...
The PowerTech V8 engine from 4.7L is compatible as a swap for the 1999-2009 model Dodge Durango, Dakota, and Ram 1500. The 5.7L Hemi V8 engine is ...
Will a 3.7 engine fit a 2010 dodge charger?
Fixya https://www.fixya.com > ... > 2010 Dodge Charger
Yes they are the same engine. Posted on May 22, 2012. 0.
Dodge Engine Swap Compatibility Chart
TrucksAuthority.com https://trucksauthority.com > Blog
The 4.7L PowerTech V8 engine is compatible for the swap with the 1999-2009 model Dodge Durango, Dakota, and Ram 1500. The 5.7L Hemi V8 engine is interchangeable ...
2001 dodge ram 5.2 motor swapped out of a 1996 dodge ram turns but don't start
Is it possible that you did not swap the ECM module along with the engine
Will a sliding back window from a 1996 dodge ram 1500 fit a 2001 dodge ram 1500 both are extended cabs?
No it won't. Only 1998 - 2001 will work. The one for the 1996 only will fit a 96 and 97. Hope this helps....
Is it easy to change a tensioner on a 99 durnago with a 318 4wd?
a single bolt in the center of tensioner no problem
My 96 dodge RAM 1500 5.9 overheated on me I stopped and let it cool down and now it wants to start but it won't
you may have damaged the internal parts of the motor. pistons/valves etc. need to do a compression check to narrow down the problem. hope this helps
How do I remove the rear sliding window on 1996 dodge 1500
the frame is not differnt on the 1996 to 1997 they are intercangeable i just put a trans from a 1999 durango in my 1500 matched up great except the shift linkage is differnt but if you keep your old linkage you will be fine
1helpful
2answers
What kind of tranny will work to replace mine?
Yes. They should both be 46RE transmissions and the bolt patterns and the plugs should be the same.
1helpful
2answers
Transmission swap
94,95 are the same 96-99 are the same. the 94-95 models have a 4 pin connector as the 96-99 have a round 12 pin connector. Hope this helps
1999 ram 1500
the part numbers are totally different between the 2 yrs....its almostn imposible to determine....you may contact a wrecking yard they may have another way to determine if they interchange
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
