SOURCE: Hotpoint Aquarius WD440 Washer/Dryer
remove bottom rear panel. you will see a large diameter hose going from tub to pump. undo this hose at the tub end - lots of water will come out. filter is inside this hose. remove and clean
SOURCE: does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
SOURCE: hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
SOURCE: hotpoint aquarius wf440 : my washing 'smells'
Try doing a couple of really hot washes without any clothes in the machine on the second one add a good dose of washing soda to the drum before you fill the machine up
Cut down on load and use some old fashioned soap powder which has bleach and other stuff in it to destroy the bacteria which is in the fats left behind in the machine because of Cool washing
SOURCE: hotpoint aquarius 1200 wont empty and I cannot
HI. the filter is mounted on the drain pump housing. You will need to disassemble the unit to access the filter. Here are some other areas i would check, also.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious issue within the actual control sector(Timer module or control board). It should be replaced i this case.
