Coleman Campers Grill Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air conditioner on pop up camper
Our air conditioner on our pop up camper will freeze up. It blows cold air but if we leave it running to long freeze appears on the part that looks like a radiator (i think that is what it is) We clean the filter and it still does it. Could it be getting low on freon? Thanks for the help.
  • rrwmkwberg Jun 22, 2009
    I'm sorry but this is an air conditioner for a camper. It only has cool low or cool high and it does it on both settings.
Anonymous
Level 2:
  • Expert 115 Answers
  • Posted on Jun 22, 2009
Anonymous
Expert
Level 2:
Answers
115
Questions
0
Helped
39476
Points
263
Yeah, it could be getting low on freon but you also could turn up the ac a bit... if your running at 68 degrees or something turn it up to 72 and it wont freeze up as quick.
CAMPER A/C FREEZES
bad thermostat or not communicating with a/c board.
1helpful
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
1helpful
My a/c in my pop up camper is blowing air but it is not cold. What should I check? Model 57915.622
Hi, this does sound as though the compressor is off. Go on top , pull the cover off and see. Turn the control to cool to see if all is running on top. You should have a disconnect at the unit. If its off, check for any blown fuses, or power to the system.
Shastalaker7 A/C Contractor
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Brick Air blowing hot air
if you hear the compressor turning on,no heat, the coolant has leaked out. if the compressor doesnt turn on, its a control issue.
2helpful
5answers
My dometic 15k brisk-air cont. cycles on-off
Actually, the dealer is somewhat correct. In the hotter months of the summer, the rooftop units have a tendency to freeze up if not run on high cool due to the lack of air movement across the evaporator. If the unit fines on High/Cool, then run it in that mode but adjust the thermostat.
It should not however, cycle on and off that fast unless you have a bad freeze switch or the incoming AC is too low. If during that 8-10 seconds, the air begins to get cold and then it shuts off, then I would say you have a bad freeze switch. If it runs fine on high, but shuts off in low, I would say it is a lack of air movement.
Hope this helps,
Jeff
Rate me please!!
2helpful
Blows but not cooling
Is compressor running. If the fan runs and the compressor runs. You are out of refrigerant or the compressor has bad valves. Please leave feedback. Rusty
The air conditioner on my pop up camper is loud and vibrating
sounds like the compressor in your air conditioner has a broken spring in it,you can not take the compressor apart to fix,has to be replaced(cashy).I assume your camper is shaking,and the noise only happens when you turn on the air.
Top Coleman Sport & Outdoor - Others Experts
Kardoc
vince
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
