Try unplugging your TV for about 10 minutes and also hold the power button on the TV for about one minute and then plug your TV back in again and turn it on to see if the white screen is still showing up again. It could be the capacitors inside of the TV have gone bad or the powerboard is not working.Check the cables and the connections to your TV to make sure they are fully connected. Or the TV connections are bad and should be replaced.
The screen cable piece for your TV falls off and causes the LCD TV to show a white screen. Most of the time here this is an easy problem to fix . Check to see which cable is loose and then reinsert it into your TV to resolve the fault. The main board that does control chip of the LCD TV's monitor is damaged or has poor characteristics which will be causing the TV to show white screen. It could also be the part inside of the TV that shows the pictures on the screen is no longer working or the capacitors are bad.
A blank white screen on the TV sometimes will show up when the TV enters into Screen saver or Daydream. Screen saver or Daydream is turned ON by default here . However, if the clock on the TV does not match that of the Internet server the TV is unable to obtain pictures from the server and a white screen is shown instead.
Check your warranty. Call for support.
*** The following is for information only.***
* If your player and TV set was working prior to this then it's probably playing a black and white movie or the TV color setting is off and needs to be reset.
* For TV go to menu, Picture, Color set up. (Best to restore to factory settings as a starting point.)
* For DVD try a known "color' movie (at least something later than 1965) if it plays in color then the older disk is B&W.
* If someone pulled out the cable (Yellow, Red, and White) this is the Video (Yellow) and Audio Left-White, Audio Right-Red.
* Check this cord for damage and reconnect into corisponding color coded jacks. Note; this cord will not affect the "color of the set other than not show up at all - Blank screen if wrong plug inserted.
* Call TV support line (or DVD support) for advice.
Aloha, ukeboy57
i have white screen on this tv no matter which input it could be on cable /tv or hdmi, dvd,etc tv stays on white screen but audio is good.. how do i fix this??? the tv dont show channels changes or setup when using control just a blank white screen.
Make sure the video/audio cable is plugged in correctly. Red cable into red socket, yellow into yellow and white into white. It is easy to put these cables in the wrong socket by accident and will cause no image to appear on your screen.
Ur Tuner board,that the tv signal came into that board.U have a little manchanical skill.Take ur tv aparts.Replaced that Tuner board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board to replacement.
My TV does this too. i know how to remove the white screen but the top will still have power only vo4.52.00 to get rid of the white screen press 'return' on your TV remote (not direct tv remote) then change the input pack to whatever it is it needs to be on to watch your (whatever)
