Question about Bulova 98B104 Mens Watch Gold Tone Stainless Steel Marine Star Black Dial Rubber Strap Chronograph
98b104 crown broken
I have a Bulova Marine Star 98b104. The crown has detached from the stem. I am having a hard time locating a new Crown assembly to replace it. can anyone point me in the right direction?
    New Friend:
  • 19 Answers
Best to go to a bulova dealer to get the original fitted as its most likely the stem is sheered of inside the old crown if however it has just unscrewed from the stem any good watchmaker should be able to refit it and reseal it
Posted on May 10, 2014
2 Suggested Answers
SOURCE:
  • 115 Answers
SOURCE: How to change the time on Bulova Marine Star.
1st: make sure the watch is set to "tme" , the botton dail display, press bottom right stem
2nd: pull out the bottom right stem ,
3rd: press the left top stem for increase time . i.e. 2:40 pm to... 2: 45pm
4th, or press the left bottom stem for decrease time: i.e. 2:40pm to .. 2:30 pm
5th: once time is good, then press in the right bottom stem,
Posted on Jul 06, 2010
Bulova Marine star 98B104 stops working when not been worn. Battery has been changed in the last few months.
Maybe "Bulova" have "Energy save mode" like my "Casio ProTrek"? Both models are quartz movement. When I don't wearing my watch he go sleep after 1 day and wake up when I pick up.
Jul 06, 2018 | Bulova Watches
My crown for my bulova precisionist watch won't screw down
It is possible a tiny gasket is inside the tread... needing to be REPLACED before proceeding.
First check to see if it is a "left-hand" or "right-hand"
threaded CROWN... Then check that there is no damage to the STEM or the CROWN... You will need at least a 10x (power) jeweler's loupe to see that.
If you have any damage... A watchmaker might be able to dress the treads and save the ORIGINAL PARTS...
Else you are probably looking at replacing both the stem & crown...
Dec 23, 2016 | Bulova Watches
Winder for automatic watch
When you wind it manually (forward or clockwise) it winds the mainspring. Only need to watch it 5 or 6 times if it's completely stopped you wearing it will do the rest. If you going to get a automatic winder get one that will wind in both directions. It will give a few revolutions clockwise and then we'll go reverse counterclockwise.
Hope this answers your questions thank you.
Jun 06, 2015 | Bulova Mens Marine Star - 98B209 Watches -...
How to set up second hand and chrono minutes for bulova 98B105 back to zero setting?
If you haven't got the user instructions you can get them via the following link:-http://www.bulova.com/watches/bulova/marine-star/98b105/
You should see "download user manual" at the bottom of the page.
Mar 31, 2011 | Bulova Marine Star Calendar #98B105 Watch...
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
How to change the time on Bulova Marine Star 100m. This is an old watch with 4 stems. 2 on each side. One is an on/off stem which is on the right side of the face.
May 03, 2010 | Bulova Marine Star 100 Meter Stainless...
The date will not change, it will with the crown but when i advance the hands it will not change.
Try to advance hands for full circle more (12 hrs more). If this does not work, then you will have to find your nearest watch repair shop, because one of the date change gear wheels is faulty.
Rate me, plz.
Jan 22, 2010 | Bulova Chronograph Marine Star #96B99...
I pulled on the crown and it came off the stem
Do not open the watch yet, as you do not know how to get the stem out.
Take an eyeglass and examine the crown. You will find the small hub in the centre of the crown. If the centre of this hub is hollow and you can see the thread in it- you will be able to screw it back on stem (all watch crowns are screwed on to stems, never pressed).
If the centre of that hub looks filled with metal, then the stem end is broke and you will need replace stem AND crown (the metal filling the hub is the broken end of stem).
In case if the crown still in tact, let me know by asking questions and I'll guide you through all the process HOW TO.
Rate me, please.
Mar 24, 2009 | Watches
Broken stem off aromen gobletover 50yrs old maker bleirristall made in bavaria.germany 24% clear stem any chance of repair have broken pieces was my Mothers passed away meens the world to me please help...
Is the stem broken near the crown? Or do you think there is enough stem to take out of crown? If not you probibly will have to go to a watchmake (NOT a watch repairman) to make you the stem. If there is enough metal to take stem out of the crown you may be able to get someone to solder the stem back together. I do that reguarly with stems that are vintage, and I don't want have the time to remake the whole stem. Let me know. Good Luck!!!!
Jul 09, 2008 | Watches
Bulova 98B104 Mens Watch Gold Tone Stainless Steel Marine Star Black Dial Rubber Strap Chronograph Logo
201 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
