How can i solve error code CC153 for konicaminiolta bizhub 164
Have a tech come and re-flash the firmware, and check the NVRAM. Firmware is only available fro secure Konica Minolta Web site they like to keep they software secure. You mite also have a bad control board. Or the memory on the board, a Tech is required.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: how to solve bizhub 211 code error c0650
C0650 Faulty scanner home position sensor • The scanner home position
sensor (PS100) does not go from HIGH to LOW when the
scanner motor (M4) is energized for a given number of steps
after the sequence to bring the scanner back to its
home position has been started at the end of a scan
motion and during re-shading. • The scanner home position
sensor (PS100) does not go from LOW to HIGH when the
after a scan motion has been started at the end of a
PS100 home check scan
