Question about MSI AE2420 3D204US 236Inch AllInOne Multi Touch Screen Desktop Black
My screen has fine lines - MSI AE2420 3D204US 236Inch AllInOne Multi Touch Screen Desktop Black
    Habit-Forming:
  • MSI Expert
  • 89 Answers
Its one of two things, either the ribbon cable is loose on the motherboard or screen side. Or, the screen is damaged...
Posted on Feb 25, 2015
SOURCE:
Removing split screen
Thank you for posting your query on fixya.
The screen could exhibit such issue , if the screen has gone bad or the video card that give signals to the screen. To isolate the problem connect the laptop to an external monitor / TV if the output on the same is fine , the video card is fine and the screen would need a replacement.
Proton
Oct 22, 2013 | Sony VAIO Computers & Internet
My satellite toshiba laptop shows a screen of fine colorful lines
did you ever try to go on gateway site to find a fix or microsoft.com to see if there is a update display driver for you computer
Feb 10, 2010 | Toshiba Computers & Internet
Fine line down centre of screen
call Toshiba ASAP if you still have warranty, the TV needs to be replaced. The line will get worse!!
Feb 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
Screen going bad?
noting to worry about untill you start seeing black lines all the time, then I would say you might have to replace the screen or the mainboard if your screen is fine.
Aug 24, 2008 | Palm Treo 750 Smartphone
Original Leapster
probably not. those lines are probably from dropping the game on the ground or water/alkaline fluid in the screen. the only way to no longer have the lines is by buying a new screen and those can cost quite a bit
Jul 27, 2008 | Toys
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
MSI AE2420 3D204US 236Inch AllInOne Multi Touch Screen Desktop Black Logo
41 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
