Question about JBL Boating
AM FM SYNC RADIO HEAD SET
MY SYNC AM FM RADIO NOT WORKING GET MESSAGE AU WHAT DOES IT MEANS DO YOU? THANKS
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: cect p168 FM Radio
The FM radio works great on the p168. You need to use the head phone that came with the phone, it has a flat plug and plugs in on the side of the phone in the usb port. If you don't have the original head phone that came with your phone I have found them on ebay. I hope this helps you.
Posted on Mar 25, 2009
dockterok
  • 603 Answers
SOURCE: no am radio but fm works fine
I don't know why you need AM, but that's not the issue.
If you have FM and HEAR it ok, then everything is fine. You've hooked it up right.
Not being able to find AM, is in the new radio.
You need to look to see how to tune to AM.
Maybe the paperwork that came with it!
Posted on Jan 13, 2010
tanmecolor
  • 10 Answers
SOURCE: i am using nokia 5233
make sure the head phones are completely inserted in the jack .
Posted on Sep 28, 2010
Mutant wifi,fm radio instruction manual,I want to know the steps to get wifi connected,from start to finish,please and thank you.
http://www.audioholics.com/home-theater-connection/how-to-set-up-wireless-router-wifi
Point 6 update the firmware - some routers won't operate on windows 8 until you log into the router and upgrade it.
Also you may want to select an actual channel number rather than set to auto as you can increase channel number by 3 to avoid interference from neighbours.
http://au.pcmag.com/networking/10051/feature/how-to-set-up-a-home-network-in-5-simple-steps
http://www.networkworld.com/article/2167574/small-business/smb-10-biggest-home-networking-mistakes-and-how-to-fix-them.html
https://www.cnet.com/au/how-to/home-networking-explained-part-5-setting-up-a-home-router/
Sep 28, 2016 | Welding Tools
How do I get the radio to play when AU is displayed?
Not familiar with this but all I can think of is battery problem; Have you tried changing them ?
If the 'AU' displayed is not in the user guide that came with it: (which is NOT available on their Website !!!!) then you should send it back under Warranty.
Complain to this bunch here.or ask them what it means.
https://www.howardleight.com/contact
Sep 20, 2014 | Honeywell Howard Leight Sync Over-The-Head...
Set radio
https://honeywell.com/Pages/contact-us.aspx
Mar 26, 2014 | Honeywell Howard Leight Sync Over-The-Head...
How to fix fm japan radio to recieve GCC fm signals ?
You can get a converter like this one.
http://catronics.com.au/fmconverter.html
It's a simple solution and it works.
Jan 18, 2011 | 1998 BMW 5 Series
I bought a '96 Mustang with an Alpine CHM 5620 CD player already installed. The unit appears in great shape and looks as if it were installed by a pro. It seems to load up the CD cartridge and change CDs...
This model of cd changer doesn't have the fm modual built into it. So I am wonder how this setup worked before. Most of these units had an FM tansmitter in them and you would just turn on your factory radio and set the fm tuner to a certain frequency like 89.5 or 91.3, not excatly sure on the right number, but somewhere low in the range. Turn on the stero and try tuning into differnet stations.
But like I said this model is desgined to be used with a aftermarket head unit with the proper wired connection going from the cd changer to the head unit.
Sep 21, 2010 | Alpine Car Audio & Video
I want to on fm without Head phone...i need code.
If you mean Nokia 2310, I don't think it's possible to play radio without headset connected to the handset. I don't believe, nokia has ever developed such a model and moreover it's impossible to play radio on nokia phones via bluetooth. If you mean other model, do let me know. Or is there any other application installed on your phone to run the radio? But in fact the handset needs the headset to run radio, so that i'll act as an antenna. Somebody uses the cut-out jack of the headset to play radio. You can try a trick, play the radio, put on the speaker (loudspeaker), then remove the headset, if it's working you are lucky. But even with Nokia N95, it's not working.
If you are sure that you are asked a code to access the radio without headset, let me know with more details.
Thanks.
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Nokia 2310 Cellular Phone
Cect p168 FM Radio
normally with the CECT p168c you don't even have a radio:s???
Mar 07, 2009 | Dual Electronics CECT P168 Cellular Phone
FM radio "Hard Error"
no hard means you have a internal hard drive problem if under warranty take it back
Feb 12, 2008 | Delstar DS 917 Digital Media Player
Boating Logo
32 people viewed this question
Top JBL Boating Experts
Gene Pitts
DocZachary
DocZachary
JonSnell Electronic
JonSnell Electronic
Are you a JBL Boating Expert? Answer questions, earn points and help others
