SOURCE: I've lost my manual and video need threading info
One of the most common mistakes with overlockers is that the threads must always be threaded in order. So if you sew about 1 inch and the thread breaks try unthreading the eyes of the needles rethread the looper and then rethread the eyes of thew needles. If not you will get the same result of sewing about 1 inch and it will break again.
SOURCE: Baby Lock Evolve wire Looper threading tool
You have to get the replacement wires from a Babylock dealer, I did too then after sticker shock at the price of that wire I learned to make a thread cradle and use that to thread difficult threads no. Take about 24 inches of regular sewing thread and fold it in half, put the open ends (together, same legnth) into the jet air port and hold onto the loop end, press the jet air threader and it will thread the machine, insert the thread you want to use into the loop you have in your hand and pull it thru the machine using the ends of the thread you put thru the machine, sounds harder than it is and works all the time. No more spending $8 on replacement wires. You can use this method for all the jet air sergers.
SOURCE: I need a new looper threading lever for the
This is the lever on the air-jet threader?
You might try the sew4less website, but may have to go to the BL dealer for this.
