Tomtom ONE 3rd Edition GPS Logo
A
Anonymous Posted on May 08, 2014
Update map of tomtom one 4n00.005
Update maps
5 Related Answers
Anonymous
  • Posted on Dec 27, 2007
SOURCE: tomtom one maps
I just had this same problem. Quite strange. I have a Tomtom One New Edition and connected to a Vista Ultimate computer. Here is what I did to fix the problem I was having.
Exited out of the Tomtom HOME application. Went to "Computer" and right clicked the Tomtom drive (was M: for me, could be different for you) with the Red Icon. Selected properties and click on tools. From there I selected "Error-Checking" and only checked "Automatically scan and fix errors for me". It said it found a couple errors and corrected it. I then doubled clicked the icon in the bottom right portion of my screen which looks like a USB plug with a green check mark on it. I selected the drive and clicked stop. I disconnected the usb plug and then used a small tack on the bottom of the Tomtom unit to reset the device. After that, I turned the unit on and all was fine and I could clearly see that an update was applied.
Good luck! They really should have a support bulletin for this as this is clearly a common issue.
Anonymous
  • Posted on Jan 26, 2009
SOURCE: After update screen just says Problem with map.
Hi, I am a complete ignoramus when it comes to this sort of thing but I am pretty sure that you have the same problem I have, I updated my GPS just like you did because, heck, that is what TOMTOM recommend and hey presto I wound up with an application 'core' of version 8.x trying to access a map with a version of 7.x. Doh! You would have thought the damn install app would figure this out and NOT install wouldn't you ? Great, I barely know how to turn on a computer and I have to deal with this ****! My GPS unit is a GO 720.
Anyway the options were to fess up $100 for the new version map - or, um, well, patch it myself :-)
At this point I decided that I would patch it myself as:  a) I hold TOMTOM completely responsible for buggering up my GPS without warning and  b) I NEED my GPS right now, not whenever TOMTOM get back to me with a reply to my query about why this happened
Here are the two links I used to patch my GPS, and yes it took a couple of hours to download and  sort it out.
http://www.gpsunderground.com/forums/showthread.php?t=2978
Where it says...
For have a working map you must:
- Patch your 'ttsystem' file and 'Tomtom Home' with this tool:
http://link-protector.com/711863/ > Just look Help
Password: demonfatal
- Use the Keygen for patch your map
Keygen for map :
http://rapidshare.com/files/187061869/KEYGEN.rar
Password : demonfatal
 (Note I selected this map and it seems to work Australia_815_2086)
The new map would not work until I replaced my 'ttsystem' file with the one from the link below - dunno why.
http://www.gpsunderground.com/forums/showthread.php?t=3619
Remember to use TOMTOM Home to back up your current GPS settings/configuration in case you balls up the patching process - frankly I don't trust TOMTOM Home to do a good enough job so maybe in addition it would be a good idea to connect the GPS to your computer and use something like Acronis to create an image...
good luck
Anonymous
  • 515 Answers
  • Posted on Apr 13, 2009
SOURCE: Brand new TomTom says no maps found after I tried to update
http://www.tomtom.com/support/index.php?Language=1&query=no+maps+found&FID=9838
Angel Dr
  • 121 Answers
  • Posted on May 04, 2009
SOURCE: gps update
i'm sorry BUT I HAVE TO TELL U THAT THERE AREN'T ANY FREE tomtom MAPS and updates unless u buy tomtom with already installed map
but there is a way to crack tomtom map
but if you're not good with pc's you can't do it
i have done it and i have to tell that is pretty complicated and is better to buy maps then try to do it the bad way
SORRy
Anonymous
  • Posted on Jun 11, 2009
SOURCE: TomTom One N14644 text to voice - I hooked it up
I do some work with TomTom - it's possible that if something interrupted or went wrong during the install, the map could have been deleted. TomTom is aware of the problem and is working to fix it - if you are map-less, call support (866 486 6866) and we can work on getting you a new map.
I would like to update the maps on my tomtom 610
To update the maps on your TomTom 610, use the MyDrive Connect software (from tomtom). If this tomtom software is not yet installed on your computer/laptop, download it from the tomtom website (e.g. www.tomtom.com) and install it. Then follow the instructions to update your map, after connecting your GPS device to your computer.
You may have to create a TomTom account (and register your device), sign in to your account, locate the replacement map or any new maps (of other regions) you wish to install, download the maps and install the map.
If you have a "lifetime" map (privilege) for your device, you won't have to pay (subscribe) for the updated map.
May 05, 2019 • Tomtom GPS
Does my tomtom have free new maps
If you had originally purchased a (new) TomTom with a "free" lifetime maps, you can download (from the tomtom website) updates to that map free, whenever that map is updated (usually four times a year).
If not, you can buy/subscribe to new maps on the tomtom website, (www.tomtom.com). Just click on "Maps & Services" ... and you'll be able to select and buy/subscribe to the map(s) you want.
May 10, 2016 • Tomtom GPS
2answers
I have a tomtom go 720 and the maps have been deleted where can i go to get them back ?
register the device, tomtom home will reinstall the original map that was on the unit when new
1helpful
Free maps downlolad
If/when you've just purchased a (brand) new TomTom GPS, you can register it (at the TomTom.com website) and download the latest map (for your device) .... free ... as part of the latest map guarantee.
Whenever you connect your GPS to the TomTom website (via TomTom HOME), you'll get (free) updates to your current map version - ... but they are NOT new versions of the maps.
To get new versions of your (current) map, you'll need to purchase the update (e.g. online, on the TomTom website). Upon paying for it, you will get the activation codes, etc. for you to download, validate and install the maps.
If your GPS has lifetime maps, (after you have registered), you'll be able to connect (via TomTom HOME) to get the latest map release, without requiring any code/password.
Jun 21, 2013 • Tomtom GPS
3answers
Trying n to up date my tomtom for more maps in the usa
This is from tomtom.com
Hope this helps looks like you haveto pay for map updates after 30 days, but I am not positive.
Application updates
We recommend always having the latest version of the TomTom application installed on your navigation device. This ensures you can use the latest features and improvements available for your device.
To check if a new version is available, connect your device to TomTom HOME and then click Update my device. For more details see www.tomtom.com/6133.
Latest Map Guarantee
Get one free map update if a new map version is released within 30 days of buying a new device.
Start driving with the latest map - guaranteed!
See What is the latest map guarantee.
Map Share™
Get daily map changes from the TomTom community.
In between map releases, you can make corrections to your map – such as road closures, and points of interest – through Map Share™ technology.
See What is TomTom Map Share.
Map Update Service™
TomTom regularly releases brand new maps that incorporate the latest changes to the road network.
With our Map Update Service you get every new release of your map over a 12-month period, from the equivalent of just €9.95 per quarter. That’s four new maps a year.
See the TomTom Map Update Service.
Single map
If you only want to update your map once you can buy a single map.
Buy a single map.
2answers
Gps update
SORRy
4helpful
DOWNLOADING UPDATED MAPS
See the following options to update maps on your TomTom:
Map Share™
Map Update Service™
1helpful
How to update tomtom 710 uk maps
TomTom makes it really easy to update maps for any one of their devices. You can get the latest Tele Atlas maps from TomTom by heading over to their Map Store. Pick your device, pick your map, and download. While they aren't free, they're extremely accurate and affordable
4answers
3helpful
Tom Tom 910 map update with 920 maps?
Yes, this is possoble.
Make sure you:
- Have updated to last navcore v7 version
- Have updated TomTom Home to latest version
Then buy and upgrade map through TomTom Home...
Find latest version of TomTom Home here:
http://www.tomtom.com/support/support.php?ID=3&Language=1
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
