Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know if where the input button is on my Philips Plasma
It is a philips plasma HDTV w/amb model number 50PF9631D/3 I can't find my instruction manual and would like to get one
Tony Nguyen
Level 2:
  • Expert 96 Answers
  • Posted on Jun 22, 2009
Tony Nguyen
Expert
Level 2:
Answers
96
Questions
0
Helped
90572
Points
270
Go to link below.
http://www.p4c.philips.com/files/5/50pf9631d_37/50pf9631d_37_pss_aen.pdf#search=%27owners%20manual%27
50pf9631d/37 have sound no picture
You need a new main board. You can order one on ebay but make sure its the correct model/serial TV number on the back label of your TV.
Problem for Philips 50PF9631D 50 in. HDTV-Ready Plasma Television I have a pwer power problem, LED flashes 7 times and will only go on on a few occasions. How easy is it to replace the...
Before replacing the capacitors check the video from this link.
The capacitors can be found here or radio shack might have them. The value should be 3300uF/25v 105 degrees radial if they fit in the space provided by design. Make sure to install them with the correct polarity.
Let me know if you require further assistance.
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
OUR 50 INCH HD AMBLIGHT PLASMA MODEL 50PF9631D HAS SOUND BUT THE PICTURE HAS MANY LINES ANY IDEAS ON WHAT THE PROBLEM IS AND HOW TO FIX??
This is know as the" Blue Haze" defect. A tech may try to lower the screen voltages for you. Realign Ve, 110volts to 100volts. Vset from 195volts to 188volts...and the Vs from 197volts to 190volts. This was an authorized fix early in 2007. But more importantly you will have to live with this, as replacing the plasma screen is very costly. You probably have a bad screen.....SORRY!!!!!!
2helpful
3answers
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
2helpful
2answers
How difficult is it to replace the power supply unit on my 50pf9631d tv?
The problem is you have to remove the back (lots of screws) and the board is expensive: Part number has changed and is: 996500042147---it retails for 305 dollars----I would not buy a used or repaired board if I were you--this is the problem with all plasma sets--they only sell boards--the ones for the Philips set are expensive.
3helpful
My Philips 50pf9631d plasma tv turns on then red light blinks 7 times! Philips no help. Local electronics store wants $500 to fix! Set is only 3 yrs old! Please help.
Are you getting picture or sound at all? If not, you could have a very common power supply failure. If you get sound or picture, then you may have a faulty capacitor or resistor on one of the system boards
1helpful
3answers
Philips 50PF9631D Plasma
First step....check power supply components.....research
similar Model & problem.................T.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
