Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
Ohh thank you eva so much!!!!
I had the same problem with the test mode, followed your instructions and all ok now.
thanks very much
tried to re do the test procedure but still failed test light still on
error comes up as Af-06
My FDW60 has stopped it's cycle just after the prewash starts running and the Eco and Fast lights start flashing at the same time. I've turned it off and reset it, but same problem keeps occuring. Any ideas?
Thanks.
i have the same problem where it just comes up test...what can i do to fix this...cheers
Also worked on WF865 with test mode showing. thank you kevin
