SOURCE: Battery fully charged, buzzing sound when i try to
check the FREEWHEEL LEVER at the rear of buggy to make sure it in the drive position, if you can push the buggy it not in drive mode.
SOURCE: Problems with Pride Celebrity X 4-Wheel Electric
It is often a damaged accelerator (Potentiometer). Sometimes the shaft on the wigwag breaks the contacts in the accelerator from being moved too vigorously when going over a bump too fast. A technician would need to repair this for you. Happy scooting. Regards Chris… [email protected]
SOURCE: The scooter will just stop and then start right
Most likely some intermittant fault condition is happening and the controller is cutting out. This could be overheating of the controller, a loose or corroded connection to battery, controller, control panel or motor, over-current in the motor or battery under-voltage. It may need someone to go over the wiring and connectors and checking everything is sound.
SOURCE: Celebrity Pride SC440 scooter makes continuous clicking sound
the motor break assembly is going bad, if not replaced soon it will quickly draw down your batteries. [email protected]
SOURCE: I have a Go Go scooter that is an older model. It
Hi, That sounds like the speed pot is faulty,
When going along push the lever in the upwards direction as well as forward , does it speed up ? does it response ? if so then that's the problem.
There could be a issue with the metal key making a good contact when inserted.
Regards
GeWiz.
Some help
My Pride Mobility REVO S3608801011G10
I got it today used the battery is on the bottom of the scooter what's the commun problem on it
