Sharp AR-150/150N/155/155N/F151 Toner/Developer 6 500 Yield Toner Developer Cartridge, Part Number AR150TD Logo
a
acho okoromadu Posted on May 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is system error L 100.
I have been using sharp arm 150 suddenly it began to show system error L 100.
George Mclaughlin
Level 2:
Sergeant:
  • Sharp Expert 372 Answers
  • Posted on May 07, 2014
George Mclaughlin
Sharp Expert
Level 2:
Sergeant:
Answers
372
Questions
Helped
128161
Points
839
L1-00 means that the scanner (the thing under the glass that scans your document) needs to be replaced. Requires a technician to fix it.
What does error code h3-00 indicate?
Sharp ARM 550/620/700 Reset Machine with Error Code ...
? 1:26
www.youtube.com/watch?v=BXs8PmMXFtk
May 5, 2011 - Uploaded by Thomas Trumpler hi thmas please tell me how to clear sharp mx-m620n copiermemory chip to use it ... How do I clear error code h3-00 on mysharp mx--453.
Sharp lcd DVD error
Suggestion. Check the battery in the remote
1helpful
Having error code H4 showing on my AR155 sharp copier. How can I resolve it please?
After error occurs please press the Start button then it shows the sub error code. I need that code to give a solution.
1helpful
Sharp EL-531WH shows ERROR 2 if I input any number over 69 as a factorial
The calculator can only handle numbers less than 10^100 in magnitude. 70 factorial is about 1.2*10^100, which exceeds this limit and hence the error.
I have a callpilot 100/150 we acquired an add-on
First thing, the Call Pilot is your voicemail, not your telephone system. Your telephone system is most likely a Norstar CICs unit.
If the lines(trunks) are analog, it is the local telco provider that is handing out your caller ID.
Outgoing caller ID is not one of the features of the system for analog circuits. If you were running a PRI or BRI, then the system can hand out the caller ID. I would ask your telco provider to check the outgoing caller ID once again.
2helpful
I tryed to have additonal speaker on my sharp cd-BA 150 player all sudden stop working and gave me an error message "PROTECT" so how do I fix that?
The output amp section for your system is not designed to run more than the speakers that come with it. By adding more, you presented too low an impedence load to the amp and overheated it. This occurred too quickly for the internal protection circuits to kick in to prevent damage to the outputs. This unit will now require that the outputs be replaced. These are not the easiest units to work on, so I would not suggest that you attempt this repair yourself. Expect a parts cost in the $35 range for this repair. Dan
3helpful
3answers
Sharp ARM-455 F202 error code and says check toner cart.
There is any solution for error F2-02 without changing any Toner Cartridge
Maytag 100 series
If the unit is just humming and then cuts itself off, you could have a defective motor. However, this same symptom could be caused by something being caught in the pump assembly.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
