Suddenly my LCD HDTV (westinghouse) got some broad vertical green and blue lines on the right side half. I am not sure whether my kids did some thing wrong.
when TV displays it have one half (50%) of the screen with a normal colour display while the other (50%) with some very bad quality with a persistent vertical broad lines of green and blue that stays there all the time. i am stuck and it has been a part of family for 2 years. i am pleading for your help and its warranty is over as well.
please help us
Try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Hi
THanks for getting back so fast...
Its a westinghouse 32" model no:SK32H240S
PART # TW 50611-C032B
its serial no. is 5061J73300693..
i am expecting your solutions or suggestions..thanks
dave
what is the model and serial number on this unit?
