no country told but 2.4L yes. did.
NO TOLD AT ALL WHAT DOES WORK RIGHT WOW.
HEADLAMPS WORK?
DOME MUST WORK TOO KEY OFF. AND HL.
THE FUSE ON DOME IS HOT ALL THE TIME
MEANS 12VDC ALL DAY LONG BATTERY NOT DEAD. SEE?
yes all cars have 2 stage or more , power system
gee just like homes really.
there is this HUGE fuse in the engine bay that feed the CAB box
of tiny fuses.
the service manual from Toyota every ever inch of this.
some cars have 3 or 4 fuse boxes. 2in cab 2 in bay
so not using the SM you miss them, the users guide in the glove box shows them,., lost that?
I will no read your manual to you, for lost
ignition on or of on dome, ecu-b no.1, and radio no.1
answer is: USA answer only sorry no books USA for outside USA>Ok?
radio dead is fuse1 or 2 blown.
so head lamps work key on and key off
starter motor dead? will not crank
IMMO lamp not showing IMMO security not failing? SMARTKEY?
dash heater blower dead too on high key on.
if all those are dead then he battery is dead for sure or fuses I list last below.(secondary fuse or primary can fail)
dead PCM ,, Fuse 1,30amp EFI-main, underhood,
lets do dome, I like easy fixeS as THOSE sure do fix the 20pageS of dead PCM?? huh)(SURE DOES)
DOME DEAD.
has only this:
the dome fuse not 12vdc both sides even KEY OFF
is a dead car battery
or FL main blown.
FL _MAIN IS FUSE LINK, 100+ AMPS IS BLOWN
IF JUMPER CABLES DO NOT MAKE ALL THINGS WORK
THE
FL_MAIN IS DEAD. BLOWN OUT.
THE PROBLEM WITH ALL POSTS LIKE THIS ONLY THE DEAD ARE REPORTED OF 100 THINGS IN THE CAR THAT USE 12VDC.
SADLY i MUST GUESS BELOW IS BAD
THIS CAR HAS VERY ODD PCM CONTROL OF HEADLAMPS
PCM DEAD HEAD LAMPS DIE, THIS IS UNSAFE,
HEADLAMPS ARE SAFETY FEATURE, THAT MUST ALWAYS WORK.
ODD THIS ,SAME GOES FOR DOME, AND IS UNSAFE, IMO
maybe the PCM has backup extra circuits to keep park and headlamps working with all? PCM fuses blown? IDK be a fun test
a car breaks down at night needs these lamps no mater what.(battery good only)
always test HL first. head. on all cars, dead. the the IMMO and last all fused, and if can scan the PCM>
