SOURCE: Hotpoint WD64, leaking water from soap drawer
your condenser is blocked,you might be lucky and get away with just cleaning it, but most of the time it is just best to change it. You will have to take the back off again it is the plastic component with the fan motor attached, disconnect the 2 black tubes to it [note where they come from] unscrew the 3 bolts at the bottom , disconnect the wires going to the fan motor. If you are going to change the condensor you will have to take the fan motor off aswell MAKE SURE YOU DISCONNECT THE MACHINE FROM THE MAINS. GOOD LUCK
SOURCE: Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
you have a blocked filter, unplug from mains, take off back panel you will see a black sump hose coming from the tub to the pump, tilt the machine forward and put a dish or bowl under sump unscrew clamp and pull off slowly to release any water in the drum. You will find a blockage, also what appears to be a ping pong ball dont throw away it is meant to be there.
SOURCE: Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
