Emerson LC320EM8 32 in. LCD TV Logo
Posted on Jun 22, 2009
Power issue NEC PX-42VM5A
I have three NEC 42" Plasma's: PX-42VM5A. Two were working a year ago when uninstalled and put in storage. Now all three behave identically and do not work:
When power button is depressed, there is an audible click (relay) the power light turns green, a few components hum then another identical click and power light goes red. A couple of times I was able ot get a glimmer of a picture on the screen, but no longer anything.
After reading earlier suggestions it seems the power supply board is likely faulty. New ones are $300, which seems to much to spend on a four year old Plasma. Anybody have an idea about what component on the power supply would be worn out?
Any insight would be great. Thank you,
Les
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jun 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
4580
Points
29
Most likely a transistor - NEC used FSM series for a while which are now discontinued. Let me know if you need info on how to find/tell which parts are bad.
  • Anonymous Jun 24, 2009
    MOSFETs used for high speed power switching are bad causing an overheating problem. Use an ohm meter to find the ones with inconsistent readings.
  • David Chavez
    David Chavez Dec 30, 2016
    This is often the culprit for SONY, Panasonic, NEC, Pioneer TV's not powering on. along with capacitors these components are the problem to almost every faulty electronic
2 Related Answers
Anonymous
  • Posted on Jun 06, 2009
SOURCE: Any idea if I can hook my laptop up to my EDTV?
Yes, if your laptop has a VGA out port (that is the external display port - usually blue with 15 pins).
The NEC display has a VGA input on the right-hand side.
You just need a VGA cable that you plug in both connectors.
Then, read your laptop manual to determine how to activate the external display (usually the FN key with an other key that has a display icon on it).
On the NEC display, make sure it is using the RGB1 input (use the remote to activate this input).
That should do it.
NOTE: Make sure your laptop is using a reasonable screen resolution (that is 640x480 or 800x600).
gopakumarg43
  • 76851 Answers
  • Posted on May 17, 2011
SOURCE: metade tela preta metade branca
Hello
From your description, I can't understand the problem of your TV well. "Half white half black screen with video signals"; you describes what? Please give me more details about the fault, as clear as you can, so that I can help you. Send these details to me by Fixya. OK.
Metade tela preta metade branca desliga com sinal de video sem sinal comtinua ligada -nec px-42vm5a
Hello
1helpful
2answers
Does anyone have the voltage specs on a PNT-426 Power Supply. It is for my NEC PlasmaSync PX-42VM5A Monitor. My electrician has found a faulty diode but doesn't have the voltage specs on it. I have a...
I have a PX-42VM5A and my Power supply is a PNT-426 (by Sanken Electric Co. LDT). Here are my specs: INPUT: AC 100-240V; OUTPUT: (there are nine outputs) +170v 1.6A; +60v 1.6A; +5v 4.0A; +2.5v 1.9A; +3.5v 1.9A; +7v 1.0A; +12v 0.5A; +12 v 1.9A and +6v 1.2A
That should do it.
Power supply issues
hi there, i recommend replacing the entire board. once you have a short like this, the micro board itself will become useless. the thin micro circuitry has become separated within the layers, preventing a closed current transfer. its best to order a new canvas so to speak.
Monitor turns off by itself
It is a power supply issue. Check this thread:
http://www.fixya.com/support/t782900-nec_px_42vp4da_stay
Problem with my NEC PX-42VP4PA
it goes on for a while and then shuts off after then the colour show not good i need help for this problem
2answers
Nec 42
who has manual for a nec 42 plasma monitor px-42vm2a date it was made is 12-07-01 it is a flat screen thank you email [email protected]
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
