Vizio L37 Television Logo
Posted on Jun 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I had some water from my plant dripped in my 32 inch Vizio LCD tv. Th e tv was off when this happened, so I try to turn it on and nothing happened. I try to dry it out with a blow dryer on warm heat. It still did not work. I am planning on letting it dry out. Will the tv still work if I let it dry out? How long should I let it dry out before trying to see if it works?
Tony Nguyen
Level 2:
  • Expert 96 Answers
  • Posted on Jun 22, 2009
Tony Nguyen
Expert
Level 2:
Answers
96
Questions
0
Helped
90571
Points
270
You should let it sits for at least 72 hours. does the TV have a orange Vizio logo light when you plug in the power? what about when you turn it on, does the Vizio logo light turns white? if yes to these two questions and you still does not have picture or sound, it could be your main board or inverter that got fried.
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
1helpful
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
1helpful
Register a 32 inch Vizio Tv
go to www.vizio.com. select the support and go down to the register your vizio. Fill out the require field and press submit. this will get your TV register.
32 inch vizio will not turn back on, just stays orange in front
Try unplugging the tv and holding down the power button for 30 seconds than pluuging it back in and if it does not come back on the tv will need a repair to the power supply, just call tech support and make sure to have the serial number and the reciet handy so they can get you registered on the support system. Hopefully your tv is still under the one year mark than the repair will be free if not it can get expensive fast. Me personnaly have worked for vizio for about a year now and honestly this is a very common problem with theses tv's.
2answers
46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
Discolored lines within picture 32 inch LCD TV
I have the same tv, if you turn up the brightness and turn down the contrast that should help a little bit.... Hope this helps
1helpful
Visio 32 with very little audio
If under warrenty then call vizio!
I believe its sound board but I could be wrong.
No easy fix, the part is 220$ service is 210 a used LIKE NEW 42-50 inch is 500$ shipped !
Sorry to say this but it happened to my 50 inch just before I heard a pop then it would not show a picture and had no sound.
Call them up if your tv is less then 1 yr old!
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
