Apple 24" iMac Desktop Logo
R
Rolando Olivas Posted on May 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Netflix runs choppy after snow leopard upgrade
After upgrading from os x 10.5.8 to snow leopard 10.6.3 streaming movies from netflix became choppy/lagging. How can I fix this.
Martin Buck
Level 2:
  • Expert 86 Answers
  • Posted on May 06, 2014
Martin Buck
Expert
Level 2:
Answers
86
Questions
0
Helped
29159
Points
131
Run 'Software Update'
This will bring the OS up to 10.6.8
Keep running software update until the system is up to date.
Testimonial: "Thanks, however, system is currently at OS 10.6.8. I've tried updating Silverlight--no joy. What's frustrating is the Netflix ran great on OS 10.5.8. Only after the upgrade to 10.6.8 did I notice the difference in play back quality."
  • Martin Buck
    Martin Buck May 07, 2014
    Run a broadband speed test to check what connection speed you are getting.If the result is low, contact your ISP and complain to them of low speed. They should sort this out. If the speed test is ok, check you are running an up-to-date version of 'Flash'. also clear all 'cookies' from your internet browser (Safari, Firefox, etc.)
4 Related Answers
Anonymous
  • Posted on Feb 02, 2008
SOURCE: unable to upgrade to system leopard on my eMac
I don't know that you necessarily have to get rid of your computer. I have a G4 circa 2000 with 400 MHz processor. I run Tiger OS 10.4.1 and can run Illustrator CS on my machine.
It is not running at lightspeed mind you but it still works fine.
There may be some interim updates that you need before going to leopard... I would try talking to someone at an apple store or call tech support about it. Apple is really good about customer service.
Your eMac has to be "younger" than my tower G4 Gigabit Ethernet model so don't give up too soon. I don't think CS3 will use like 50% more resources compared to CS so your computer should be able to handle it.
Good luck,
Jim Thomson
  • 1099 Answers
  • Posted on Aug 30, 2010
SOURCE: I've inherited my brother's old Mac Mini (upgraded
If you have the instal disc boot up the mac with it holding down the c key. Once it has booted up you can then go up to the menus and use the change password command. Then restart. Hope this helps.
Anonymous
  • 481 Answers
  • Posted on Nov 01, 2010
SOURCE: Runs very slow with frequent spinning wheel.
Usually, the beach ball indicates low memory, but it can also indicate lots of disk retries.
First stop would be Disk Utility, to see what the SMART status for the drive is If it shows bad, that's definitely your problem - if it doesn't show bad, it's still inconclusive.
You can also look for disk retries in the Console log, but that requires knowing precisely when the symptoms were happening, and is pretty boredom-intensive.
I'd boot this machine off an external OS drive and see if it showed the same symptoms. If yes, I'd look at testing the memory. If no, I'd replace the hard drive.
Permissions aren't going to be the problem if you've freshly reinstalled the system.
Jim Thomson
  • 1099 Answers
  • Posted on Jun 25, 2011
SOURCE: getting a imac g5 all in one power pc 1.8 gb os x
Unfortunately Snow Leopard requires a intel processor to work so the G5 imac will not be able to run the system.
tip
How To Upgrade Mac OS X Tiger 10.4.* to Snow Leopard 10.6.*
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the <a href="http://www.amazon.com/Apple-MC581Z-A-Mac-10-6-3/dp/B002I0JKE2">10.6 Box Set</a>.<br /> <br /> <span style="font-weight: bold;">System Requirements to run Snow Leopard:</span><br /> <ul> <li>Mac computer with an Intel processor</li> <li>1GB of memory</li> <li>5GB of available disk space</li> <li>DVD drive for installation</li></ul> <span style="font-weight: bold;">Snow Leopard Installation Instructions:</span><br /> <ol> <li>Just insert the DVD in the optical drive.</li> <li>Restart your Mac while holding down the C key.</li> <li>You will be guided through the installation procedure and be prompted at one point to choose which install option you want.</li> <li>Once the Snow Leopard install is completed the Mac will restart itself.</li> <li>You will probably be asked to register with Apple upon restart.</li> <li>Enjoy Snow Leopard on your Mac!</li></ol> <b>Q: Can I upgrade directly from Mac OS X 10.4 (Tiger)?</b><br /> <br /> <i>A: Yes. Apple recommends purchasing the Mac Boxed Set for this purpose, which will also update iLife (it is unknown at the time of this writing whether older versions of iLife work with Snow Leopard) and iWork. Also note that while it has been said that the $29 upgrade will work with 10.4, it is not officially supported and may be in violation of the licensing terms.</i><br /> <br /> <b>Q: What happened to the different install options? Can't I do an Archive & Install?</b><br /> <br /> <i>A: Apple has revamped the familiar installation options for Mac OS X. You now have two choices, either a straight upgrade or a clean install. Supposedly if you choose to do a straight upgrade, what actually goes on behind the scenes is what was traditionally known as an Archive & Install.</i><br /> <br /> <b>Q: Is there anything I can do to better prepare myself for the upgrade?</b><br /> <br /> <i>A: Yes. It is advisable to run a Verify/Repair Permissions and Verify/Repair Disk in Disk Utility. You may also want to run the maintenance tasks in <a href="http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html">Onyx</a>. And finally, it would be wise to get your applications up to date using a program like <a href="http://metaquark.de/appfresh/">AppFresh</a>.</i>
on Feb 16, 2011 • Apple Mac OS X
I am running OS X 10.4.11 and would like to upgrade my operating system?
Please provide more information.
To what would you like to upgrade it?
Since OSX Mavericks was just announced, I'm going to assume that's what you're wanting to upgrade to.
Not all Macs can run Mavericks.
Mavericks Capable Macs
Mavericks, like its predecessor Mountain Lion, requires one of the following Macs with at least 2 GB of RAM and 8 GB of available hard drive space:
  • iMac (Mid 2007 or newer)
  • MacBook (Late 2008 Aluminum, or Early 2009 or newer)
  • MacBook Air (Late 2008 or newer)
  • MacBook Pro (Mid/Late 2007 or newer)
  • Mac mini (Early 2009 or newer)
  • Mac Pro (Early 2008 or newer)
  • Xserve (Early 2009)
If your Mac isn't one of the ones listed above, you won't be able to upgrade.
If you have an iMac, MacBook, MacBook Pro, or Mac mini model that was originally released in Early/Mid 2006, the latest version of Mac OS X your system supports is Snow Leopard.
http://store.apple.com/us/product/MC573/mac-os-x-106-snow-leopard
I HAVE AN APPLE POWERBOOK G4 I PURCHASE FROM EBAY IT IS CURRENTLY RUNNING MAC OS 9 ,HOW CAN I UPGRADE TO OSX 10 ?
Hi Bobby
You will need to get an OS X installation DVD. Try eBay.Don't go for anything lower than 10.4 (Tiger)10.5 (Leopard) and 10.6 (Snow Leopard) should run fine on this machine.Don't bother with 10.7 or 10.8
How do I upgrade to 10.5 or .6?
Firstly you will need to buy a copy of 10.6. This is available from Apple (see link below) or you could get a copy from eBay.
Mac OS 10 6 Snow Leopard
The following article will tell you what to do next:
An Easy Guide to Installing Basic Upgrades in OS Snow Leopard 10 6
Getting a imac g5 all in one power pc 1.8 gb os x 10.3 computer. can i upgrade to snow leopard v 10.6.3 with disc ?
2helpful
2answers
Hi, Went to the Mac store to upgrade to Snow Leopard and was told my OS was "way too Old to upgrade to Snow Leopard!" Sorry, I'm a numbskull when it comes to these things. Figured as long as...
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the 10.6 Box Set.
  • Mac computer with an Intel processor
  • 1GB of memory
  • 5GB of available disk space
  • DVD drive for installation
  1. Just insert the DVD in the optical drive.
  2. Restart your Mac while holding down the C key.
  3. You will be guided through the installation procedure and be prompted at one point to choose which install option you want.
  4. Once the Snow Leopard install is completed the Mac will restart itself.
  5. You will probably be asked to register with Apple upon restart.
  6. Enjoy Snow Leopard on your Mac!
A: Yes. It is advisable to run a Verify/Repair Permissions and Verify/Repair Disk in Disk Utility. You may also want to run the maintenance tasks in Onyx. And finally, it would be wise to get your applications up to date using a program like AppFresh.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Can I upgrade my Macbook Pro to more than 4GB ram?
4GB is the MAX but only 3GB is utilized.
What Os are you running. Tiger Leopard Snow Leopard?
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
