You either have water with a high sulfur content or need to flush your heater. you should flush your heater every year anyway. you can turn off the water and electric to the heater. and totally drain the tank when it is totally drained add more water and drain some more. then refill the tank and run a hot water faucet the tub is best to eliminate any air in the system then turn the electric back on this should solve the problem if it does not you probably have sulfur in the water and would need water treatment or filters to help
SOURCE: i just installed an 80 gal rheem tall water heater
Hey check out this link that I found on this matter I hope will help you with this.
http://homerepair.about.com/od/plumbingrepair/ss/trblsht_hwh_5.htm
