The remote senosr on my LG LCD TV went out 3 months after I bought it and was repaired under warranty. Cost to LG was $409.63 for an IR board ($14.37), Main Digital Board ($195.26) and trip charge ($200.00).
Now 2 years later it has stopped working again and I am wondering if I could replace the parts myself. It took the guy 15 minutes to repair it the first time. Also wondering if the IR board is typically the problem or if one board affects the other board. It would be great to fix it for a $15 board. I was also searching the web for an appropriate LG service manual (not owners manual).
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
065 244 405 318 037 398 191 459 245 389 060 275
742
743
726
508
584
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*
Point the Sky+ remote control at the TV and try the volume button.
OK.
B52Tony:
Thanks for the help! Remote works on another LG LCD. So I guess the first step to to replace the IR board. Hopefully the Main Digital Board (the one they replaced before) is okay - TV works okay off of the manual channel, volume, menu buttons.
Replaced the IR board (EBU 36136201) and the remote still does not work. Guess I will have to replace the Main Digital Board. Price on a new one is now over $300.
