E000 Heater temperature fault (fails to increase) E001 Overheating detection error E002 Heater temperature error (fails to reach specific level; inadequate increase) E003 Heater temperature error (abnormal drop; low-temperature detection) E007 Fixing film rotation error E010 Main motor rotation error E014 Fixing motor rotation error E019 Waste toner case full, sensor error E032 DA unit communication error E051 Horizontal registration HP detention error E064 Power supply voltage error (high-voltage error) E100 Laser BD error E110 Polygon motor rotation error E202 No. 1 mirror base HP detecting error E204 ADF image leading edge signal detection fault (absent) E220 Lamp ON error E225 Standard white plate/edge white plate read error E240 Mcon-Dcon communication error E243 Mcon-control panel communication error E248 Backup (EEPROM) error E261 Zero-cross signal error E302 Shading error E315 Image data processing error E601 Image transfer error E602 Hard disk error E604 Image memory fault E605 Image memory battery fault E606 HDD error E674 Fax board error E677 PDL board mounting error E710 IPC initialization error (Rcon) E711 IPC register error (ctrl) E712 Communication error (with ADF) E713 Communication error (with sorter finisher) E716 Communication error (with pedestal) E717 Communication error (with ASSIST) E719 Card reader, coin vendor communication error E732 Reader communication error E733 Printer communication error E737 SDRAM error E740 Ethernet board error E741 PCI bus error E742 RIP1 board error E743 Mcon-Rcon communication error (Rcon detection) E744 Language error E746 Resolution conversion board error E803 MPWS power supply voltage error (low voltage error) E805 Fan rotation error E901 Pedestal main motor rotation error [ADF] E420 Back-up data read error E421 Back-up data write error E422 IPC error [Saddle Finisher-G1] E501 Communication error (Punch unit) E505 Back-up RAM E510 Feed motor E514 Delivery motor E530 Width plate shift motor E531 Stapler motor E532 Stapler slide motor E537 Alignment motor E540 Tray ascent/descent motor E577 Paddle motor E590 Puncher motor E592 Puncher sensor error E593 Puncher shift motor E5F1 Saddle folder motor [Finisher-J1] E500 Communication error E514 Stack handling motor E530 Rear alignment motor E531 Stapler motor E537 Front alignment motor E577 Delivery motor E580 Delivery tray ascent/descent motor E585 Stack handling error
If the thermistor has a short circuit, the indication in service mode (COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Precor has standardized their error code messages across all their equipment so that each error will have the same meaning regardless of what model or equipment type the message appears
Here we list each error so that you can click through the specific error for additional details about the cause and action to correct the error
E000 Insufficient temperature rise of the fixing unit at power-on E001 Abnormality of the fixing unit E002 Insufficient temperature rise of the fixing unit E003 Low temperature of the fixing unit after standby E004 Error of the protection circuit in the fixing unit E006 Connection error of the fixing unit E008 Life expectancy of the fixing roller E010 Main motor error E012 Drum motor error E013 ITB waste toner full error E014 Fixing motor error E020 Drum/Developer-related error XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color E021 Developing rotary error E026 Toner empty error XX=01:Y XX=02:M XX=03:C XX=04:K E032 The counter of the NE controller fails to operate. E045 OHP sensor error E067 High voltage-related error E070 ITB HP detection error E100 BD error E110 Operation error of the laser scanner motor E202 CIS unit HP detection error E225 CIS light quantity error E227 Power supply error in the reader unit E243 Control panel unit error E248 Backup memory error E315 Abnormality of image data E351 Main controller PCB error E400 Feeder communication error E490 Model error E500 Finisher communication error E503 *** Finisher internal communication error E505 Finisher backup memory error E514 *** Stack delivery error / **** End assist motor error E519 **** Gear change motor error E530 *** Rear alignment error / **** Front alignment error E531 Staple error E532 Staple unit shift error E535 Swing error E537 *** Front alignment error / **** Rear alignment error E540 *** Stack tray up/down error / **** Upper tray up/down error E542 **** Lower tray up/down error E577 *** Paddle error E580 Stack tray up/down error E584 **** Shutter unit error E590 ***** Puncher motor error E591 ***** Puncher dust sensor error E592 ***** Puncher side registration sensor error E593 ***** Puncher shift motor error E5F0 **** Saddle paper positioning error E5F1 **** Saddle paper folder error E5F2 **** Saddle guide error E5F3 **** Saddle alignment error E5F4 **** Saddle rear side staple error E5F5 **** Saddle front side staple error E5F6 **** Saddle paper push-on error E5F8 **** Saddle connector error E5F9 **** Saddle switch error E601 Abnormality of image memory E602 Hard disk error E604 The image memory (SDRAM) is faulty/insufficient E609 * Abnormal low temperature of the hard disk E610 ** Failure in the hard disk cryptographic key E674 FAX board communication error E677 Abnormality of the external controller E710 IPC initialization error E711 IPC communication error E712 Communication error between the ADF and the reader E713 Communication error between the finisher and the printer E717 Communication error with the NE controller E719 Communication error with the coin vender/card reader E730 PDL error E731 UFR PCB error E732 Reader communication error E733 Printer communication error E740 Abnormality of the Ethernet board E743 DDI communication error E744 Language file/BootROM error E745 * Token ring board error E746 * Option board error E747 Main controller PCB error (Image processing ASIC or memory control/communication control ASIC) E748 ** Main controller PCB error E749 ** Restart in accordance with a change of the product configuration E803 Door close error E804 Controller fan error E805 Fan error
