HEWLETT-PACKARD HP G62 Notebook Logo
Posted on May 06, 2014
How do I recover from usb or recovery partitoin when winload.exe not found
I have been trying to recoverwindows 7 to this laptop from a usb key made by a HP tool and from a recovery partition. The key would not boot untill I got easyBCD to create the boot files. I used easy BCD to create many different options but all end up with file: \windows\system32\boot\winload.exe not found Status 0xc000000. I put a copy in all drives in \windows\system32\boot\ with the same result whether I boot from USB or HDD. Windows start up repair finds no problem with the start up. I tried activating the system partition and the recovery partition with no change. I have been at this for two weeks using F11 key, bootrec, bcdedit and now easyBCD. I have about 15 bcd backups. Do you have any ideas I may have missed?
Harshad Agre
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 06, 2014
Harshad Agre
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
116
Points
7
First change your RAM and again try recovery
  • peaceleslie May 06, 2014
    changed ram same result
    I tried to buy the recovery CD;s from HP america but they could not process my card so I am stuck with the options of the recovery patition or recovery USB
How to recover HP laptop from usb or recovery partition when winload.exe not found?
don`t loose time.
back up your files....
format and install windows from a disk!
4answers
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
1helpful
2answers
Recovery toshiba satellite m305 s4819
Recover windows password not a difficult thing.
I also forgot the password of my toshiba a few days ago,but I recover
windows password now by a software called Windows Password Reset ,
it is easy and effictive to use,and all systems support.
I hope it can work out for you too.
10helpful
3answers
I have a compaq presario CQ57 laptop and forgot my password
I have experienced the similar problem as yours. I forgot my HP Compaq Win 7 laptop password, finally got out of problem by DIY a password reset disk with Windows Password Recovery Tool 3.0. Your blank bootable USB Flash Drive will help you much now!
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
New pc core i3 intel orignel mother board DH55TC DDR3 2+2 RAM DVD R/W VIP SMPS PROBLEMI NSTOL WINDOWS 7 &VISTA BOOT CD 1 STEP :- WINDOWS IS LODING FILE STEP :-2 ERROR LODING WINDOWS 1 PLS INSURT CD AND...
Here is a possible fix found at the Microsoft knowledge base .
read and follow the instruction given.
If you are not comfortable with the registry fix then you may have to call the mother board tech support for further instructions but this is found in the Windows 7 environment or operating system.
Article ID: 927392
7answers
Windows 2000 password
Things went a little bit different when it comes to reset password for Windows Server 2000, for most of its users do not know how to create a windows password reset disk. Well, you could also create a password reset disk with a CD/DVD or USB drive on all popular Windows system while you take use of the third party software, the Windows Login Recovery Ultimate.6_29_2012_2_19_34_am.jpg
Winload.exe
Hi there.
When you turn the laptop on, keep pressing Alt+F10. This should open the recovery program. Follow the on-screen instructions for factory settings.
Let me know if this does/doesn't work.
Tim
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
